weird escos troubles
Old Jan 9, 2008 | 08:33 PM
RoyP's Avatar
RoyP
Default weird escos troubles
hi all
i have a weird problem with my escos,
it only revs up to 4000 rpm and only givs about 0.5 bar off boost, what can this be?
sometimes i goes like it should, but after 2 or 3 times i keeps hanging up at 4000 rpm again, its a big turbo cos.
things i was thinking about that could be wrong are
-ECU
-Chip( getting another one this week)
-actuator
-vacuum leak?
do you have any ideas? or had this yourself?
regards
roy.
Old Jan 9, 2008 | 08:42 PM
dave green's Avatar
dave green
Boost leak ,
Old Jan 10, 2008 | 08:21 AM
tommeke's Avatar
tommeke
ECU
we had also the same problem on our own car
change the ecu and all things go back as normal
change the whole ecu, not only the chip!
cheers,
Old Jan 10, 2008 | 08:28 AM
kjc300's Avatar
kjc300
It sounds like limp home mode to me!!!
One of the sensors is probably knackered, it defaults to a 4000 rpm rev limit on a fault.
Old Jan 10, 2008 | 10:22 AM
xxshepxx's Avatar
xxshepxx
Camshaft sensor
Old Jan 10, 2008 | 12:02 PM
karl125's Avatar
karl125
i had the same problem. changed the map sensor and it's perfect now.
Old Jan 10, 2008 | 01:24 PM
vinnya77's Avatar
vinnya77
I had this also, it was the 2 main loom connections under the vent, cut these out, replaced the corroded wires with new wire soldered it up and away it went.
Old Jan 10, 2008 | 05:53 PM
RoyP's Avatar
RoyP
well, now your all saying something else , i change the chip and ecu first and then ill see if sorted, i already know about the problem with the 2 main loom connections, but they are still in good condition on mine,
ill keep you posted
Old Jan 10, 2008 | 07:20 PM
kjc300's Avatar
kjc300
I would try swapping sensors first as the ecu is SUPPOSED to do that fault if one of the sensors is down.
Have you got a mate nearby with a working cossie? Get him round and do some swapping!!
Old Jan 10, 2008 | 08:12 PM
RoyP's Avatar
RoyP
yeah swapping isnt a problem, you know of jp-cars in the netheralnds? its family, so that wont be a problem
Old Jan 10, 2008 | 08:21 PM
kjc300's Avatar
kjc300
I have yes, saw them at landgraaf, 2 years running when I was in germany!!
In that case may as well nick an ecu as thats easiest to change lol!!
Old Feb 15, 2008 | 02:40 PM
RoyP's Avatar
RoyP
Default Re: weird escos troubles
hi all. still having troubles with my escos.
already changed:
-ECU
-Chip
-Crancksensor
-Lambda
-Map Sensor
-ignition
but its stil in safe mode
anyone with any ideas???????
hi all
-ECU
-actuator
-vacuum leak?
regards
roy.
Old Feb 16, 2008 | 12:27 PM
oldford's Avatar
oldford
Roy, since this ecu is in limp home mode, you must be able to read one (or more) troublecodes. So, first thing is to get the codes read. A simple led-tester will do that, but you can also use a star-tester. Then you know which circuit (doesn't have to be the sensor itself, can be wiring loom also) is causing the problems. Saves you a lot of time searching and trying.
Other way of testing is using a break-out-box and checking the signals with a DVOM.
gcfcos
59
Oct 6, 2015 05:04 PM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 11:21 AM
Mickeystewart
Sep 9, 2015 04:04 PM
