Who has the 20 sec interior light delay?
When selected, my owners manual says that after shutting the door, the interior light should stay on for 20 secs, unless the key is turned to ignition which will then turn the light out.
Mine turned off as soon as the door was shut, so I checked behind the fusebox to locate the delay relay and found a metal link inserted instead!
Has anybody else got this setup, or do you have the delay relay fitted?
Gez
Gez
just swap the metal briding pin out for a relay
like this
http://cgi.ebay.co.uk/FORD-ESCORT-5-...QQcmdZViewItem
will work as intended then
like this
mine was the same i think its where its had a new fuse box at some point. i just put a relay in there and it works fine now
if you want to check the options on your fuse box the wiring diagrammes show you what fuses and relays should be fitted
It's a Lux version, don't know if the fusebox has been replaced in the past.
I've ordered a relay, so should be sorted hopefully.
According to the manual, R10 is 'Engine running' and R11 is'Air con, ABS,or Fuel injection system'. Other codes are not listed.
Cheers, Gez
Cheers, Gez
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
155lee
Oct 24, 2015 11:11 AM
The Enigma
Sep 12, 2015 10:12 PM
