Latest engine pics from AVA
Was over at ava this morning to see how my car was coming along and was real happy with the work and the car is nearly ready to start. They still have the vernier pulleys to fit and adjust to get the car drivable to run in as the part map in the ecu is from my old spec. New inet is done, remote oil filter fitted and oil cooler mounted behind the drivers side 500 grill. All the pipework from the new proalloy cooler is 3" inc the tb
Comments welcome
Comments welcome
Yip should be ready to pick up in 3 weeks when i get home from work, was all the little bits that have been done that impressed me. Was all mnt to just be pushed on fittings onto the fuel reg and rail but is now jic fittings with compression fittings onto the original pipework. Oil filter is now under the t/b so easy to change and pipe in well.
plenum looks cool with fuel reg on it etc.
All the wee different bits make the car
Im running a ford thickwall cased plated front diff, full mullit spec rear and will be using a mullit box.
Going to hopefully be maxing out the CR turbos T38 justnow hoping for around 360/380 atw at ava , the last one Alan mapped on that turbo made 360 but wasnt pushing the turbo.
Because mine is a sharp elbow hose i might end up just getting a boss welded onto the hard pipe where it comes out the cooler. Were not running the turbo cooler anymore with the bigger rad and cooler so have space above the rad that a valve will fit nicely. Might even buy AndyR's foofoo valve.
Good to meet you Neil - sorry I was in a rush yesterday but got my exams and need to get on with a bit of work!
Fingers crossed for you getting fun out of it when you get back from the pleasure island that you are currently on
Scott hopefully yours shouldnt be too long now since it looks like they are starting to clear there feet of other projects.
Lawnsy Thanks
hopefully it will be out the shed and on the rollers for map tweaking soon.
Lawnsy Thanks
Basic spec is :
Mountune WRC block
Ceramic coated low comp JE pistons
Arrow rods
CNC big valve head, with extra hand finnishing
+1 mm Ferrera valve , double springs, titanium retainers
Mountune cams, piper vernier pulleys
Seimens 83lb/hr injectors
Ava inlet with 3" tb
Mongoose exhaust
CR Turbos T38
Collins ECU
Remote oil filter and cooler
Mountune WRC block
Arrow rods
Mongoose exhaust
CR Turbos T38
Collins ECU
Lawnsy Thanks
Lawnsy Thanks
Scott :Mine is trying a few new things for ava but nothing compared to your car. Think i seen some cooler end tanks infront of it the other day but dont know if they were for your car or not, wasnt realy down in the bottom shed as mine is next to the rollers now.
Yip the 29th so hopefully get over that week to pic it up. Will give Alan a phone a few days before i get home and update you on here(bastards at work have blocked msn
). I does look good was impressed when i first lifted the bonnet at the work thats been done, will look better once all the bufty bits are refitted and its had a good clean up.
Originally Posted by wayneclayden
Neil, what did you do for ahose on the throttle body side?
Is that a roose one? or did AVA source it??
