cosworth denso coil on plug upgrade!!! *lower price!*
Old Jan 6, 2008 | 04:11 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
Default cosworth denso coil on plug upgrade!!! *lower price!*
as title if your running aftermarket management these are the perfect coils to use to convert to coil on plug all work perfect and come with the plugs youl need with wiring diagram. these are genuine not sftermarket and are about £100 each give or take so are very cheap at £100 delivered
Old Jan 7, 2008 | 12:18 AM
markk's Avatar
markk
what are they off and do they bolt to the rocker cover on any existing holes ?
are they a honda part?
Old Jan 8, 2008 | 09:24 PM
NEEDFORSPEED
hi, the coils are denso of a toyota, not the same as the ones on my engine, they mount at slightly a different angle. im sure they will mount in existing holes yes, mine would i just tapped them so they looked streighter. i will check for definate and take a pic if you like??
Old Jan 8, 2008 | 10:23 PM
markk's Avatar
markk
yes please.
cheers
Old Jan 9, 2008 | 03:26 PM
NEEDFORSPEED
yes they do fit in the original holes! i removed one of mine to try
Old Jan 10, 2008 | 09:34 PM
NEEDFORSPEED
upski
Old Jan 15, 2008 | 07:04 PM
pieterjan's Avatar
pieterjan
Hi
from what type of a toyota are they?
Old Jan 15, 2008 | 07:58 PM
NEEDFORSPEED
yaris
Old Jan 20, 2008 | 10:21 AM
NEEDFORSPEED
anyone!
Old Jan 20, 2008 | 10:36 AM
NEIL A's Avatar
NEIL A
What is needed to fit these will they work with any cosworth ecu converted for coil packs.
Old Jan 20, 2008 | 10:43 AM
NEEDFORSPEED
i dont see why not mate youd just link 2 together. possible change to the charge time but i think it would be ok best asking stu
Old Feb 15, 2008 | 07:29 PM
NEEDFORSPEED
up
Old Feb 20, 2008 | 01:57 PM
NEEDFORSPEED
up
Old Nov 14, 2010 | 07:04 PM
Slyman's Avatar
Slyman
Originally Posted by NEEDFORSPEED
yaris
TOYOTA 90919-02240??
How did you find they worked???
Old Nov 14, 2010 | 07:40 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
needforspeed , anychance of a copy of the wiring diagram
i now have your old rocker
dont suppsoe you know the colour code of the paint u used do you ?
Old Nov 14, 2010 | 10:42 PM
Slyman's Avatar
Slyman
These are the angled versions 90919-02239
These look like they bolt on the original holes, but Im not sure if they come with a horizontal pin connection instead of angled up?
I think these are a aftermarket set here on a lush YB-
Old Nov 15, 2010 | 06:21 PM
SierraCos2wd's Avatar
SierraCos2wd
jesus lives good....
what type of coils are on the last photo?
Old Nov 15, 2010 | 06:28 PM
Slyman's Avatar
Slyman
I'm trying to find that out, aftermarket versions of the Denso 90919's
Old Nov 15, 2010 | 06:35 PM
SierraCos2wd
send me a pm if you find that out mate
Old Nov 15, 2010 | 07:17 PM
Slyman's Avatar
Slyman
Will do
Old Nov 15, 2010 | 07:48 PM
-beefy-'s Avatar
-beefy-
why not just get in touch with prep n play who built it ?
Old Nov 15, 2010 | 07:55 PM
Slyman's Avatar
Slyman
Sent PM's, no reply as yet
Old Nov 15, 2010 | 07:58 PM
-beefy-'s Avatar
-beefy-
lol ,
well if you go the stock yaris option , ive got his modded cover if you need any measurments fella
what management you planning on running ?
Old Nov 21, 2010 | 11:35 AM
Slyman's Avatar
Slyman
Cheers Beefy, how far flat are the covers 'towers' machined down?
Should be using either DTA or MoTec
j.hammond1
30
Oct 31, 2021 05:28 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Anutternutter
Aug 21, 2015 06:07 PM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
