cossie fan problems
Old Jan 3, 2008 | 10:26 PM
argescoz's Avatar
argescoz
Default cossie fan problems
Can any 1 help got an electrical problem with my small turbo cossie... drove it earlier for ten minutes parked it up and came back 2 hours l8r and the fans were still running had to pull out the fuse to stop it... any ideas what the problem is?? cheers
Old Jan 3, 2008 | 11:17 PM
The Youth.'s Avatar
The Youth.
either the fan relay has stuck or the switch in the rad has, the switch would be my first port of call, quite cheap to! the esc cos has a 2 stage switch so remember to get the right one.
steve
Old Jan 3, 2008 | 11:58 PM
morty's Avatar
morty
Had the same problem with my Cossie also (Large Turbo model). I changed the switch on mine also. But now mine is being plugged into my new ecu so that i dont have them problems. Meaning the fans come on sooner than the 103.6 degrees that they did come on at.
Old Jan 4, 2008 | 09:49 AM
JanDK's Avatar
JanDK
I have had TWO fanswitches burn of in ONE month!! Now I drive aftermarket with only one switch built in. IT works
My fan relay havent failed yet..
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
