ABS pump
Old Jan 3, 2008 | 02:13 PM
stookay's Avatar
stookay
Default ABS pump
mines is playing up , is the pump on 2wd same as escos ?
regrds stookay
Old Jan 3, 2008 | 03:25 PM
mikedaf2's Avatar
mikedaf2
similar but not the same the connectors are diffrent for a start but if you get one off of a grany the same age it will be the same exactly.
Old Jan 3, 2008 | 03:52 PM
Bullett's Avatar
Bullett
i have a 4x4 saff one for sale.you are talking the bit near the turbo?black round ball shape unit with the clyinder and pump attached?
stookay's Avatar
stookay
thanks mate
Old Jan 3, 2008 | 04:13 PM
stookay's Avatar
stookay
aye am not sure if it all one unit or i just need the bit that plug goes into,
am going to see if i can power up mine direct from battery , incase it wiring / fusebox fault , when the snow stops of course
Old Jan 3, 2008 | 04:20 PM
Bullett's Avatar
Bullett
snow!i should be so lucky!
i know if its that bit you cant get it all seperate.i treid to buy just the bottle and ford said doesnt come seperate and the whole lot is 1700quid
strangley i just cleaned it
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
