Grp A Escort Cosworth suspension Guru's
Need a little help finding a few prtas and pointing in the right direction if you please
I would like to keep my current uprights and hubs but use the Anti roll bar setup of a Grp A Car like Martin at Reyland has done here
Hope you dont mind me using your picks as an E.G. Martoon
things i am loking for are the Anti roll bar mount which the blue cross member looking thing, A Grp a bladed anti roll bar set and a Pair of Compression struts
im not worried about the Track Controll Arms as they will have to be modified from standard items
Does anyone have any of the above parts know where i might find them or know who i should contact about them
Thanks very much for your time
Ben
Ben
alot of martins suspension there are bespoke items, the steeringrack extenders, longer tcas and comp struts, the blue part is just an antiroll bar mount /sump guard mount they used to use on early cars, i sold one about 6 months ago.
Xen i will probebly be corrected but i was told if you didnt want to use an ARB you had to have super Hard suspention which isnt pratical for what i want
markk Have the steering rack extenders as i have longer drive shafts
how much did you sell your antiroll bar mount /sump guard mount for and who was it too, do you know if they are usig it?
Charlie Chalk Martin is busy enough without me driving him mad all the time looking for parts
he will only have to try and sorce them the same as me anyway
you have saved me the job now anyhow as im sure he will see this post and have somthing to say about it
i only used the alloy mount to hold my sump guard up, and cant rememeber who i sold it to, made about £100 though just for the xmember
Anyone shed any light on that please?
Thanks
You can get the lot through Julian Godfrey or email him at Racetuners.You might flinch a bit when the prices come up though.I'm still looking for 2 drop links myself and i'm so desperate i'm going to have to go to Demon theives.
Originally Posted by allsteel
Just seen that Martin has his blades set to medium for stiffness.You can alter the position of the blades 3 ways.
jessie_rs
11
Jun 3, 2019 04:57 PM
ile take 2
