mondeo diesel td endura help
right i need to crack on and sort this fookin mondeo.
Car hesitates under load after 2.5k and splutters etc, smokes when under load and is returning 30mpg on long runs,
ive turned pump up.... down.... boost up,..... down...... adjust what i guess to be some sort of advance on top of pump linkage but still does it.
any ideas before i burn it?
as above check the timing and check the bolts going through the timing pully on the pump are in the middle of the groves not at eather end....
AND you will laugh at this one but try the deisel filter
timing is the obvious 1 and is what ill look at 1st, filter did cross my mind also, cars done 96k and sounds sweet enough when running just drives like a dog!!
any other input, hopefully its 1 of the above and an easy fix
yip try them first.....nothing much realy goes wrong with themive had loads for run abouts and i just got a mk2 td endura and it stands me at Ł200 with a years test, ford cd player, tow bar, air con.....lol
They just plod on forever.....
unless ya get a mk3 then you WILL have loads of shit with the injectors....
MK2 p plate 1996? mondeo, the top of the pump is damp with diesel but no signs of where its come from, will try to get out and peg up see if timings right, and change filter, fingers crossed
The pump normal starts to leak out the seal behind the pump pully due to the power steering belt going hard and people tightening them right up to stop them slipping.....
Just thought to there is a thin metal pipe comes from round by the turbo to the bottom right of the pump to adjust the fueling when on boost.....there is a little rubber pipe join's this to the pump ya car'nt miss it as it is like a cone shape ( thinner at one end then gets bigger for pump end ) these are prone for splitting and makin the car run shit....
advance solenoid on the side of the pump...where the small boost pipe goes too , there very common does it surge on idle and the needle lift sensor have a do with itself also know to run on there own oil if not careful
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
The Enigma
Sep 29, 2015 10:31 AM
