330mm disk kit with 2wd 4 pots....
2x 330mm disks with bells with good 2wd calipers with spacers fitted to accept the thicker disks and hi spec brakets and bolts.
all pistons move in calipers and pads have lots of wear left..
can also have std 2wd disks..
£220 ono.
will be heavy to post so if you know a cheap courrier you could arrange.
if not im down in devon but can meet up near to london either off the m4 or m3 a few times a week.. .. thanks
£220 ono.
Russ Payne
Sep 25, 2015 08:29 PM
