cam belt timing cossie
Old Oct 12, 2004 | 12:29 PM
yogi's Avatar
yogi
Default cam belt timing cossie
hi just want to no how to time her up ive got the diagram wiv everything showing me were to be just want to no how to do it do i loosen od the belt tension pulley then just adjust everything then put cambelt back on tighten the tension back up help will be grat cos dont want to damage any valves lol
Old Oct 12, 2004 | 12:32 PM
3drbadboy's Avatar
3drbadboy
make shore you get the bottom pulley on no1 pick up lug not on the line in the pulley i know a lot people who have made this mistake
Old Oct 12, 2004 | 12:35 PM
yogi's Avatar
yogi
the grove in the pulley is that wat you mean that goes just past the tdc line and the lug lines up wiv the tdc line is that write
Old Oct 12, 2004 | 12:37 PM
3drbadboy's Avatar
3drbadboy
yes mate line it up with the no1 peg not the line
Old Oct 12, 2004 | 12:48 PM
3drbadboy's Avatar
3drbadboy
shit drawing but you should get what i mean from it lol
yogi's Avatar
yogi
wat about the auxillary shaft does the marker go at 1 0clock
Old Oct 12, 2004 | 12:51 PM
3drbadboy's Avatar
3drbadboy
if you look at your dizzy there is a mark on the top edge which you line the rotar arm up with
Old Oct 12, 2004 | 03:15 PM
yogi's Avatar
yogi
write got another problem carnt find no markings to time the crank pulley up wiv as anybody got a pic of wat the lug should be timed up wiv carnt find no marks or nothing
Old Oct 12, 2004 | 03:51 PM
3drbadboy's Avatar
3drbadboy
here you go
Old Oct 12, 2004 | 03:52 PM
St3V3_C's Avatar
St3V3_C
If you look down below the alternator you should see a bit of metal sticking out from the block. It's at about the 10 o'clock position on the pulley.
Old Oct 12, 2004 | 04:38 PM
yogi's Avatar
yogi
yeah ive looked for that is it like a thin bit of metal stinking out which joins onto the block i bit further down
Old Oct 12, 2004 | 04:43 PM
3drbadboy's Avatar
3drbadboy
yes it is a bit of metal sticking out
Old Oct 12, 2004 | 04:45 PM
ImaRacing 700's Avatar
ImaRacing 700
If you NEVER done this before be VERY careful and make sure you wind her over manually a few times to make sure no piston valve contact
Old Oct 12, 2004 | 04:54 PM
Gav Diamond's Avatar
Gav Diamond
There is a post in the essay section
Old Oct 12, 2004 | 06:19 PM
yogi's Avatar
yogi
for gold members only well up to now i have lined the cam pulleys so arrows pinting to each other in middle put aux shaft towards dizzy mark put crank pulley lined the lug up wiv the metal thingy sticking out of block so now just put the cambelt back on and tighten the tension up then turn the crank pulley by hand a few times to see if any noises like valves hitting pistons
Old Oct 14, 2004 | 11:43 AM
yogi's Avatar
yogi
all done soughted started first go but i never replaced the rocker cover gasket wiv a new 1 just put the old 1 back on do i need a new 1 as it was a new 1 last time i had the rocker cover off about 3 month ago or do i just put some gasket sealent over it ect
Old Oct 14, 2004 | 12:30 PM
3drbadboy's Avatar
3drbadboy
i would replace it mate if you dont it could leak oil in to the plug holes and it makes a big mess to clear up
RUBY123
Oct 22, 2023 12:04 PM
cos elle
Sep 1, 2015 06:48 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
