wat size socket for crank pulley bolt cossie
Old Oct 12, 2004 | 12:08 PM
yogi's Avatar
yogi
Default wat size socket for crank pulley bolt cossie
aa above need to go and buy a socket for it but dont no the size
Graceland's Avatar
Graceland
Team HOTHOT!
19mm if i remember rightly
or 3/4" if you are old skool
Old Oct 12, 2004 | 12:13 PM
3drbadboy's Avatar
3drbadboy
no its 24mm
Old Oct 12, 2004 | 12:15 PM
FletchCossie's Avatar
FletchCossie
As 3dr said its 24mm You will need to stop the pulley from spinning when trying to undo/tighten it tho
Graceland's Avatar
Graceland
Team HOTHOT!
ooooops
slap me about a bit then
Old Oct 12, 2004 | 12:16 PM
yogi's Avatar
yogi
well ive just changed the tappets so need to retime it just double checking the top cams timing point to each other
rst-s1
Aug 23, 2015 07:56 AM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Zoggon
Aug 10, 2015 10:39 AM
lockie
Jul 31, 2015 10:03 PM
