sierra 1800 bits needed
Efi conversion by anychance?
Go to you local scrappers mate, they're full of 1800 sierras
You might need the timing belt cover too, its got the cps bracket built into it
Rare as rocking horse shit now mate, doubt you'll find any more 1800cvh's in any scrappies they've all been raped of those bits!
However, i just so happen to have all the bits you've listed! What you offering??
I am working on trigger rings and sensors with brackets to fit with standard cvh crank pulley that will fit with either cvh or zetec bottom ends! but won't be ready for quite a while yet
Also, if it's on a fiesta, you don't want the alternator bracket as it makes the alternator adjust the opposite way to a fiesta and will foul your lower rad hose ( had this problem on mine! )
Use the standard alternator bracket and i made a bracket to move it over 15mm, basically the bracket bolts to the original 4 holes then the alternator bolts to this
i made mine 10mm thick if it helps??
PM me m8...
