1959 anglia 100e
Old Dec 18, 2007 | 09:52 PM
mk1racer's Avatar
mk1racer
Default 1959 anglia 100e
Right thought i would put a quick post up of my project, not going to put all the pics up 2nite as there is quite a lot of them Anyway while im here, will introduce myself. Im dan i live just outside of bath in wiltshire. This is my 4th ford so far first was a mk1 xr2, then mk6 1.8 si escort, followed by an immaculate mk5 rs2000 and sold that due to being too nice to drive and bought this car instead. Plans with this car are to Bring it into this age a bit more and make it more driveable so i can use it daily for work. Basicaly plans are 2l zetec, 5 speed type 9, capri front suspension, escort world cup crossmember, 5 link rear end to get rid of the horrid leaf springs. Right onwards with the pics as i picked it up, i picked the car up for £400 locally, has 38k on the clocks with 3 owners i think, was a 1.1 with a 3 speed gearbox before i started. If you want to know anything more then just ask
When i have more time i will put a lot more pics from so far in the project
Cheers Dan
Old Dec 18, 2007 | 10:08 PM
joshF's Avatar
joshF
looks like a good un
il watch this one
Old Dec 18, 2007 | 10:22 PM
The Youth.'s Avatar
The Youth.
Hi m8, great project! I have owned my 100E for nearly 17 years now, took me 9 years to build it, keep updating your progress,
fancy 5 linking the rear of mine as at the mo it's only got tramp bars and panard rod
steve
Old Dec 19, 2007 | 01:17 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Cool car, i'll be watching this
Old Dec 19, 2007 | 01:23 AM
mad dog younge's Avatar
mad dog younge
get it built mate .hope you are going to track her
Old Dec 19, 2007 | 12:16 PM
the saint's Avatar
the saint
thats cool mate i have one of these (1961) it has a 1600 xflow in her at the mo
Old Dec 19, 2007 | 02:40 PM
haz87's Avatar
haz87
Bloody hell Dan, get the updates up! Its come a long way since those pics
Old Dec 19, 2007 | 02:47 PM
Nash's Avatar
Nash
Cake lover!
I love 100E's
Old Dec 19, 2007 | 06:09 PM
Simmo's Avatar
Simmo
These are ssooooooo cool!!!... keep the updates coming...
Old Dec 19, 2007 | 06:34 PM
mk1racer's Avatar
mk1racer
Not going to see a track i have this car for those duties
Will get some more pics up in a bit, going for a shower now
Old Dec 19, 2007 | 07:08 PM
mk1racer's Avatar
mk1racer
Right then, car coming apart, engine out etc
Random stuff collected for the car from various corners of the uk
Old Dec 19, 2007 | 07:11 PM
mk1racer's Avatar
mk1racer
interior out to inspect floors, which are perfect really
More parts bought, escort world cup crossmember and mk2 escort adjustable tca's
Picked up a mk2 escy rs2k diff cheap
Old Dec 19, 2007 | 07:17 PM
mk1racer's Avatar
mk1racer
Made up some conversion plates for the capri struts to fit the 100e mounts
And in place
Escort crossmember modified to fit the 100 chassis rails, also tca's fitted along with a newish escort steering rack
Bulkhead cutting to make room for the zetec to fit
Old Dec 19, 2007 | 07:21 PM
mk1racer's Avatar
mk1racer
Engine mounted
Moving onto making room for the gearbox
Perfect hole size
Metal removed so far
Gearbox from underneath
Old Dec 19, 2007 | 07:25 PM
mk1racer's Avatar
mk1racer
had to try some wheels in just to see what it looks like
Made a gearbox mount for it
Other half of mounts in teh chassis rail
Mount fitted
And from above
Engine and gearbox sitting nicely
Old Dec 19, 2007 | 07:31 PM
mk1racer's Avatar
mk1racer
moving onto the rear suspension, taking old axle out, loads of room underneath the back of the car to work
Disc kit
£10 ebay win, brand new inlet
Old Dec 19, 2007 | 07:32 PM
mk1racer's Avatar
mk1racer
more when photobucket stops buggering about
Old Dec 19, 2007 | 07:35 PM
Charlie Chalk
Unknown.
Cool
Old Dec 19, 2007 | 09:32 PM
MAD EVO 4's Avatar
MAD EVO 4
Brilliant project mate
Old Dec 19, 2007 | 09:51 PM
B19LRW's Avatar
B19LRW
Its Broken.....
bit of a clever old stick!! the fabrication looks well!! cant wait for updates!
Old Dec 20, 2007 | 03:27 PM
smithy20vt's Avatar
smithy20vt
Dan now i can see why you built that fook off big garage.
That is seriously cool
Neil
Old Dec 20, 2007 | 05:19 PM
mk1racer's Avatar
mk1racer
i love the garage hows the baby doing neil? not seen you over at your parents in ages. Right then some more pics as photobucket is playing today.
Got my machinest at work to knock up a few bushes for the 4 link set up
And the rose joints for them, cheap ones for now to make sure everything works as it should, My other half arranged them neatly for me
105 axle in place on the old springs to check the brakes etc all fit as they should
And general pic of it sat on my pugs track wheels
Headlining and glass coming out, think is the job i hated doing the most so far on my car. Really did not want to drop it
Old Dec 20, 2007 | 05:24 PM
mk1racer's Avatar
mk1racer
More cutting to the bulkhead to fit the inlet manifold
Fudge collared me into buying an water manifold at the same time as him for his 3dr in teh hope of getting them cheaper, turns out that tactic doesnt work So more cutting to get the water manifold and exhaust manifold in
Started on the link bars for the rear axle and also made some mounting plates
Roughly made a bit of tunnel up as well just to pass some time at work one friday afternoon
Old Dec 20, 2007 | 05:28 PM
mk1racer's Avatar
mk1racer
Went on a bit of a buying spree to try and get some enthusiasm back and got these items
Then back onto the rear axle, took it into work and tacked the 4 link mounts in place
And back home that evening to offer it up with 4 links held up on a jack to get some vision of what it will look like
Another quiet friday afternoon at work ment i made some mounts for the shell
Old Dec 20, 2007 | 05:34 PM
mk1racer's Avatar
mk1racer
Final update for the minute as its too cold to go outside
shell mounts temporarily bolted on for the minute
And axle bolted on
Few general shots of it sat on the ground to try and get the height right, also trying different wheels on from my workmates mk1 escort
I need to make a panhard road up next and then decide if i can use the coilovers i have bought, if not i will put them on the rear of my pug and buy some new ones. Once the rear suspension is all working as it should i will move back to the tunnel and get all that fabricated, i need to get hold of an appropriate starter motor as well. Still a massively long way to go with it yet
Anyway hope ive not bored you all too much, update after xmas i think when i will hopefully take the car into work for a weekend of effort
Old Dec 20, 2007 | 07:50 PM
tessatony's Avatar
tessatony
top work mate
Old Dec 20, 2007 | 08:00 PM
GUZZLER's Avatar
GUZZLER
awesome work
Old Dec 20, 2007 | 09:19 PM
ram's Avatar
ram
Has a large member
Old Dec 20, 2007 | 09:58 PM
COLEYST200's Avatar
COLEYST200
nice work mate do you do any work when your at work
Old Dec 20, 2007 | 10:40 PM
Dan16v's Avatar
Dan16v
great stuff mate, keep it up n dont let the cold get the better of you
Old Dec 21, 2007 | 08:35 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Blimey the 100E brings back memories owned one of these in 1963.
1172cc sidevalve & 3 forward gears.
I wish you well with this project, it sure is going to be a lot quicker than my old girl which mustered less than 40 horses .
Old Dec 23, 2007 | 03:33 PM
Fastas's Avatar
Fastas
great project
Old Dec 23, 2007 | 03:59 PM
robertthorpe's Avatar
robertthorpe
wikid mate!!!! love to see the old skools are still being made into beasts!!!! looks like someone is pretty handy with a welder!!!!!
Old Dec 23, 2007 | 04:45 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
you not finished it yet mate?
bout time you got some pics up lol
you have made some good progress since i last seen it!
i think i still have the starter from the type 9 on the 3dr if you want it?
it might have gone tho
keep it up mate
PS Dan is the chap who made the roll cage in my car, and the engine mounts. he works for caged in frome and is the shizzle with a welder!!
Old Dec 24, 2007 | 01:48 PM
mk1racer's Avatar
mk1racer
thats for the comments Have you still got the starter off the dohc orange thing? i think that is the one i need
Old Dec 24, 2007 | 02:44 PM
MAD EVO 4's Avatar
MAD EVO 4
brilliant work mate
Old Dec 24, 2007 | 06:05 PM
marky_g's Avatar
marky_g
Fleet Manager
top fab work mate
Old Mar 16, 2008 | 01:55 PM
mk1racer's Avatar
mk1racer
been a while since an update so here goes. bought some compression struts and tried them for size, due to nothing really being available for the 100e i am having to modify mk1/1 escort stuff really
Also bought a watts link very cheaply, need to make some new mounts for it
Made a few little bits to start boxing the bulkhead back in again, Card template first off then make in metal
And the whole lot together
Have been measuring up for plates as well this morning and thinking a bit more about the bulkhead, need to make a access hole in it to get to the gearbox bolts and thermostat bolts
Thats all for now cheers Dan
Old Mar 21, 2008 | 10:03 PM
mk1racer's Avatar
mk1racer
have made use of my day off work by going to work haha. Thankfully it was spent doing stuff for my 100e. Have re-done some mounts for the watts link as the ones that came with it were no good really, easier to make new ones then modify them to fit. so heres some pics
Old Mar 21, 2008 | 11:56 PM
hai07222's Avatar
hai07222
Alot of great work. good job
