Fiesta RS turbo exhaust manifold for a top mount turbo
Dose anyone know of anyone who dose a manifold for a Fiesta turbo that a top mount turbo will fit, (pref with external wastegate pipe)
Or is there any other manifold that will do the job?
Any help would be gratefull as have a top mount turbo and don't see the piont of buy'in another turbo
so the way the turbo is at mo if i was to fit it the oil feed/return are on each side, if i was to do what you said would that make them top and bottom? and is it really that simple?
yes it really is that simple, the 3 sectionf of the turbo, the compressor housing, oil bearing & exhaust housing can be loosened and twiseted to any orientation you need and then tightened back up again.
Simple
Dan
Simple
Dan
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
track.focus'd
Aug 12, 2015 05:53 PM
