Billet cams brand new £150 plus vat
1st to 200 without NOS
Hydraulic or mechanical profile (can supply mechanical lifters cheaply too) cams brand new from billet blanks (not reprofiled) to any spec £150 plus vat and postage.. Can help with profile choice if needed.
DO NOT PM OR EMAIL use the phone 0121 458 6010
can u post a set of bd10's in cyprus and how much in euros?my specs are:200 wire rung long studed block,je pistons with valve cut outs,carillo rods,balanced lightened crank flywheel crank pulley,polished ported gas flowed head,gas flowed inled t/b,polished exaust manifold,garret gt30,tial 38 mm externall,motec m48,coil pacs,mongoose exaust,hks frond mound intercooler.are the cams suidable for my spec?open to sugestions.thanks!!!!
id be after the bd16s for that spec id think
i dond wand the car to be "wild" in idle because its my everyday car.also i used a ball bearing turbo for the car to be smoother instead of kicking u when on boost.my engine i curendly being build by andonakis the man who owns the silver 1000bhp escord cossie(ff cover may 07)and he sugested a pair of bd14's to but i wanted a second opinion...are the cams per pair?i will need a pair of puleys as whell.can u suply apackage and postage?and how much? (if posible in euros? thank's a lot for your time col cos!!!
Hi Martin, any cam recommended for more power on a std comp stg3 YB Cos engine, I believe std comp etc. Is there anything else available to help a YB that will sit near the limiter a lot without taking the head off?
if you told me that in the first place I would have!!
sent you enough emails and pms and I aint going to chase you around for a pair of cams. as it so happens im sorted now anyway so thanks but no thanks
