zetec alloy underdrive pulley
for escort/ fiesta
new in box £39 delivered.
ive got one fitted to mine and they work a treat, they are 30mm smaller than std and about a third of the weight!
you need to shave the lip off the plastic cover that sits behind the std pulley.
you cant see the lip with the std pulley still on as its inside the std pulley but this smaller one requires the lip removed so the belt doesnt touch it.
it improves performance and lightens the bottom end.
they are gorgous;
they are gorgous;
