Very Important RE SECS S8
When mapping it make sure the laptop doesnt go into stand by mode...if it does and you turn it back on the S8 Software seems to corrupt...so in affect any adjustments made are corrupt too and can seriouly kill your engine
If you put a new map in.....it will also be corrupted
UNLESS you switch off and re start the software.
Make sure you turn stand by mode OFF.
UNLESS you switch off and re start the software.Make sure you turn stand by mode OFF.
