What chip is this?
Old Dec 4, 2007 | 04:26 PM
Jonny81's Avatar
Jonny81
Default What chip is this?
When i got my cossie a few weeks ago i was told it was standard, when i took a mate out in it he said it felt quicker than other 4wd cossies he'd been in & it got me thinking...
So today i took the top off the ecu & found this
Theres a sticker on the chip that says " NEW 4x4 PC" Does any one know where these chips came from or have any info about them? Hopefully its not some ebay crap.
Also it has this actuator
I was told that this actuator isnt any better than the standard one so does that mean the car won't be stage 1? Im hoping not cos if it is then stage 1 isnt very fast! lol
cheers
Old Dec 4, 2007 | 04:35 PM
BIL N KEL's Avatar
BIL N KEL
how much boost is it running?
Old Dec 4, 2007 | 04:44 PM
Jonny81's Avatar
Jonny81
Thats the thing mate i dont know, theres no boost gauge yet. I'll hopefully get one fitted at the weekend. Just hoping some one might have seen or used one of these before.
cheers
Old Dec 6, 2007 | 09:40 PM
G 74F 00's Avatar
G 74F 00
HI JONNY YOU SHOULD RING TURBO DYNAMICS AND GIVE THEM THE NUMBERS THEY ASK FOR OFF THE STICKER ON YOU ACTUATOR. THEY SHOULD BE ABLE TO GIVE YOU THE SPEC OF YOUR TURBO.
THEY'RE NUMBER IS 01202487497.
WHAT INJECTORS ARE IN YOUR CAR?
Old Dec 6, 2007 | 10:06 PM
Jonny81's Avatar
Jonny81
Hi mate, i didnt know i could do that, i'll give it a go cheers do turbo dynamics do chips? The injectors are standard. thanks
Old Dec 6, 2007 | 10:18 PM
G 74F 00's Avatar
G 74F 00
NOT SURE IF THEY DO CHIPS I SPOKE TO A GUY CALLED ADAM HE WAS USEFULL. BUT IF YOU GOT STANDARD INJECTORS I CANT REALY SEE IT BEING ANYMORE THAN STAGE 1.
Old Dec 6, 2007 | 10:22 PM
Jonny81's Avatar
Jonny81
Yeah the turbos probs just been re-con'd there before, im just confused cos i thought it needed a -31 actuator to be stage 1, things will hopefully become clearer when i fit a boost gauge tomorrow & see whats going on
Old Dec 7, 2007 | 06:06 AM
Norwegian Wolf's Avatar
Norwegian Wolf
You might need a -31 to run stage 1.
A stronger acturator is needed when you run higher boost.
Wait until you get a boost gauge to se if it manages to keep the boost stabil on high rpms, if it doesn't you might buy a stronger acturator such as a -31. If the one you have is an original one.
Old Dec 7, 2007 | 12:54 PM
orion turbo's Avatar
orion turbo
i hade a turbo dynamics actuator on my turbo found out it was a -31
looked just like that one.
Old Dec 7, 2007 | 01:52 PM
Jonny81's Avatar
Jonny81
Got the boost gauge fitted today & the car is running a huge 0.5 bar!! lol No idea why its that low but how exactly do i adjust the actuator to raise it a bit?
Thats assuming the boost gauge is correct, does -0.3 bar sound about right at tick over?
Thanks
Old Dec 7, 2007 | 07:19 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
MINE RUNS AT -20 PSI ON TICK OVER SO DONT WORRY - IS NORMAL ON TICK OVER
Old Dec 7, 2007 | 08:56 PM
Jonny81's Avatar
Jonny81
I wound the rod on the actuator in about 5 turns & it only gave me about 0.2 bar of boost, is that normal?
cheers
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
RSmark84
Sep 13, 2015 01:29 PM
