**SOLD**
Old Dec 4, 2007 | 02:06 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default **SOLD**
These injectors are what did 350bhp on my little CVH with room to spare. They are excellent and proved to be lovely to control so we were able to have great off-boost fuelling.
They have seen about 2000 miles usage and cost around £350 from places like Jabbasport. I'd take £175 inc postage.
An excellent alternative to Greys and a direct fit. Here is the data.....
Part Number 17113738 (OE # 17104487)
Static Flow Rate: 50.0 lb/hr @ 43.5PSI (300kPa) 525cc/min or 6.4gm/sec
Static Flow Rate: 57.7 lb/hr @ 58.0PSI (400kPa) 606cc/min or 7.4gm/sec
Dynamic Flow Rate 2.5ms pulse width and 10ms repetition rate @ 43.5PSI (300KPa): 1.1 gm/pulse
Dynamic Flow Rate 2.5ms pulse width and 10ms repetition rate @ 58.0PSI (400KPa): 1.3 gm/pulse
Coil Resistance: 12 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Factory Tollerance: +/-5% (actual +/-7%)
Cone Spray Angle - 22.4 degrees - single spray cone. Approximate cone angle for 90% of spray volume
Connector: Minitimer (Bosch EV1)
Ball/Seat Design with 6-Hole Diffuser Disc
Flowed and grouped to within 1% tolerance using Racetronix custom injector flow bench.
Old Dec 13, 2007 | 01:42 PM
Christian and Beccy
#1 in Spelling Club
These are on Ebay, finishing tonight. Someones gonna get a bargain!!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=tab%3DSelling
