Moding HT leads
Got a set of motorsport leads that are not that old and now i want to mod them for the clip type fitting (Coil pack conversion). Any one know where to get this type end
did mine, all i did to use the coil pack ends (took them off an old set) was cut the rubber(use heat shrink to reseal) outer cover and then remove the metal terminal that is crimped to the old lead.
this might help
https://passionford.com/forum/viewto...ighlight=leads
should only take about 20 mins to do
this might help
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
The Youth.
Sep 30, 2015 09:59 PM
