Cossie poly bushes!
Old Dec 3, 2007 | 06:35 PM
cameron2's Avatar
cameron2
Default Cossie poly bushes!
What part of a saff is recommended NOT to polybush? Rear arms? Why?
Old Dec 3, 2007 | 06:58 PM
dojj's Avatar
dojj
Resident Wrestling Legend
bearings not bushes
or that they are a right fooker to get out
Old Dec 3, 2007 | 08:36 PM
cameron2's Avatar
cameron2
No, no. Poly bushes not wheel bearings!
Old Dec 3, 2007 | 10:45 PM
col cos1's Avatar
col cos1
pm kev sharp hel sort you out
Old Dec 3, 2007 | 10:58 PM
charlie luciano's Avatar
charlie luciano
Polybushe everything except the rear trail arms, reason fooks the ride up
Luciano
Old Dec 4, 2007 | 08:41 AM
broos3's Avatar
broos3
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Would the reason not to repalce the trailing arms with poly bushes, because that the trailing are are fitted with spherical bearings not rubber bushes?
So if the bearings are damaged eg too much play then replace them with standard items not poly bushes.
Bruce
Old Dec 4, 2007 | 02:46 PM
Alan s1's Avatar
Alan s1
Default Re: Cossie poly bushes!
The Bushes are Rose Jointed so best to leave them as standard
Old Dec 4, 2007 | 02:56 PM
I have always poly'd the rear arms, yet to find a arm with a bearing in it!!
Never not once had any trouble bushing here, but on the beam had masses of trouble with poly here, ie way too much vinration.
Old Dec 22, 2007 | 12:01 PM
moonstone mike's Avatar
moonstone mike
I had this problem going round my head for months .
I decided to poly the lot........seems fine
but lots of work doing the rear
Old Dec 22, 2007 | 05:09 PM
I have fitted before a GGR axle tightening kit with escort std beam bushes(FORD) and I must say it felt a lot better than poly on there.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
DavidK
Sep 27, 2015 02:55 PM
