Head gasket on a cosworth
Old Dec 1, 2007 | 01:23 PM
cos400's Avatar
cos400
Default Head gasket on a cosworth
How hard is it to do head gasket on a 2wd cosworth?
Old Dec 1, 2007 | 01:40 PM
It wont be that hard i know a lad who can get them off in 45 mins.
Old Dec 1, 2007 | 04:50 PM
dave cos4x4's Avatar
dave cos4x4
if you are not confidet enough i suggest you take it to someone who can sort it for you.
Old Dec 1, 2007 | 05:01 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
piece of piss mate
Old Dec 2, 2007 | 04:50 PM
Niall.b's Avatar
Niall.b
Just like a cortina
Old Dec 3, 2007 | 10:42 AM
costina's Avatar
costina
Live long and prosper!!
Originally Posted by Niall.b
Just like a cortina
just don't time it like a cortina!!!!!!
Pistons touch valves= could be expensive!!
Paul
Old Dec 4, 2007 | 01:39 AM
Norwegian Wolf's Avatar
Norwegian Wolf
About 2 hours, if you have experience..
Would recommend you to let somebody who is, change it for you.
Sorry about the bad english, i'm from Norway
Old Dec 4, 2007 | 09:05 AM
foreigneRS's Avatar
foreigneRS
Testing the future
very simple if you follow the procedure in the workshop manual
undo and do up the bolts in the correct sequence
easier to remove the head with inlet and exhaist manifold in place. don't forget to remove the turbo oil drain - easiest is to disconnect it at the short hose where the outlet pipe joins to the sump
make sure that your head and block are in good condition and flat
make sure you get all oil and water out of the head bolt holes
cut the heads off 2 of the old head bolts, cut a slot in the top with a hacksaw in case you need to use a screwdriver to get them out, and thread them in only a couple of turns to use as a guide for the new gasket and to put the head back down square
get a cometic cam cover gasket as they are re-usable and sseal better in the first place.
use new rubber seals around the cams and plenty of sealant around the cam bearings
Old Dec 4, 2007 | 12:51 PM
Staffi's Avatar
Staffi
Good Man Nick..
Old Dec 5, 2007 | 07:07 PM
Sideways_Sierra's Avatar
Sideways_Sierra
simple as that
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
mrknifey
Aug 30, 2015 11:48 AM
turbotrev
Aug 22, 2015 11:41 AM
Aug 14, 2015 07:29 AM
