How much uncle freeze for my RST?
I dont want to put it in my tank as it leaks when i start it up jusnow
(might aswell play along lol)
SOOOOO
I'll put it in my COOLING system instead
eh eh, so how much should go in their, thanks for the input chop i'll bear that in mind if i ever get it to crail
(might aswell play along lol)SOOOOO
it depends how cold it get oooop north, as obviously daaaaan saaaaf the mix is a little weaker
Mind, you, its not like the cars goin anywhere is it dear boy
50/50 mix of AF/Water should be ok i would have thought
Tbh mate i never use water in any of my cars,just fill em up with neat coolant(it has water in it anyway)stops the cooling system rusting up and keeps em mega cool.......................Not had any probs in 20 years....
As coolant has much better heat transfer properties wtf would you want water for........it boils earlier and doesnt get rid of heat as good as coolant !!!!........so your motor will run a little bit cooler if ya got more coolant in.....
Actually there aint that much difference but coolant also has rust preventer in int so thats gotta be good for ya engine....
i have known people to run with neat ( just anit freeze) with no probs but most put a mix in, book say 40% mix, but i alway put 50% in my fiesta rs and it runs in the middle of the temp gauge near on all year round unless its real hot weather then it creeps up abit if in traffic.
if your book says 7.8L total coolnt, then stick 3.9L anitfreeze in, cant go wrong.
if your not sure if's its strong enough ( which it would at 50%) get a anitfreeze tester.
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
