are impreza engines 'safe'? - UPDATE - fixed!
Old Nov 29, 2007 | 08:17 AM
foreigneRS's Avatar
foreigneRS
Testing the future
Default are impreza engines 'safe'? - UPDATE - fixed!
the bolt through the eccentric idler pulley snapped in half last night and lost belt tension it had moved to the outside edge of one cam pulley (bottom right as you stand in front of the engine bay looking into it) and was still turning it though.
are these engines safe, or am i likely to have bent valves on that side?
the other side of the engine still had both cams in sync
Old Nov 29, 2007 | 08:36 AM
GARETH T's Avatar
GARETH T
its an interference engine
Old Nov 29, 2007 | 08:41 AM
stage 3 muppet's Avatar
stage 3 muppet
do a compression test and find out pal saves ripping that head off damn boxer engines
Old Nov 29, 2007 | 08:48 AM
foreigneRS's Avatar
foreigneRS
Testing the future
it's nearly as easy to take the head off as it is to get the compression tester in there
might have the engine out and freshen it up - it has done 120k so is probably due new gaskets
Old Nov 29, 2007 | 09:27 AM
Jay,'s Avatar
Jay,
Sponsor
bad news nick
Old Nov 29, 2007 | 09:35 AM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
i had a 4 cam turbo that had a smack on the drivers side
that broke 1 pulley and bent another one, it pulled the timing belt
so hard it pulled the threads outa shape holding some tensioners,
it had a new belt and pulleys/the block machining and tapping and by turning over by hand all seemed to be ok, so we started it and it was fine,still pooped meself though
on them engines,valves do valves not pistons into valves
Old Nov 29, 2007 | 11:46 AM
GARETH T's Avatar
GARETH T
Originally Posted by EsCosRacer
face it.....its not called a poobaru for nothing....they are shit and will always be shit.....
you do hate them dont you mate?
ive been tempted to buy one
Old Nov 29, 2007 | 11:52 AM
mrjenrst's Avatar
mrjenrst
Must admit i'm not a fan but i think that's got more to do with the chav element.
That the majority of chav's own one or aspire to own one.
Old Nov 29, 2007 | 05:32 PM
the original's Avatar
the original
I think it will be ok.
based on no facts whatsoever
just know how lucky you are
Old Nov 29, 2007 | 06:13 PM
Ive seen a rally car impreza that had a smash on the front end and the cam covers were smashed and the cam pulleys which were plastic were smashed to causing damage to the engine. Plastic pulleys whats that all about. A shit idea if you ask me.
Old Nov 29, 2007 | 06:43 PM
_DAN_'s Avatar
_DAN_
Yoon
I've seen an Impreza on ScoobyNet (Flat_Four) which was in a smash before he got it and the impact smashed the pulley (inlet?) on the right hand bank as you look at the car.
Old Nov 29, 2007 | 09:20 PM
foreigneRS's Avatar
foreigneRS
Testing the future
that's not standard and is a good idea for a rally car as they don't need to last long and will have less weight and inertia
morto's Avatar
morto
put a 4g63t engine in it and see what the scooby guys say
andy
Old Nov 29, 2007 | 10:00 PM
AlexF's Avatar
AlexF
If you need a hand matey - I'm curently building a STi lump
Old Nov 30, 2007 | 07:46 AM
foreigneRS's Avatar
foreigneRS
Testing the future
do you a swap then
saw an old boy in a subaru pickup this morning and stopped him to see if he would sell. would be the ideal time to transplant everything and freshen up the engine with new bearings and head gaskets while it's out.
offered him a grand but he wouldn't go for it. said the pikeys pay more than that to have them for hair coursing
told me where he lives though, daft cunt. might have to go and help myself one night
Old Dec 2, 2007 | 09:44 AM
AlexF's Avatar
AlexF
I was thinking about this yesterday and was going to suggest new bearings at the same time
Old Dec 2, 2007 | 10:08 AM
A lad i work with has been rebuilding an impreza for his friend cause it has been smashed up on the drivers side front. He said the same about the plastic pulleys been smashed to,cause the car has been hit that hard on the drivers side front. Thats a road car to.
Old Dec 2, 2007 | 11:54 AM
the original
How did you get on yesterday Nick?
Old Dec 2, 2007 | 07:07 PM
foreigneRS's Avatar
foreigneRS
Testing the future
got the snapped bit of bolt out with much grief and snapping of easy outs haven't got any further than that
Old Dec 3, 2007 | 09:07 AM
foreigneRS's Avatar
foreigneRS
Testing the future
got the cam belt back on and it runs a treat - no bent valves
bedford track day here we come
Old Dec 3, 2007 | 04:13 PM
Well done mate you lucky git.
Old Dec 3, 2007 | 04:16 PM
RichardPON's Avatar
RichardPON
Standard exhaust mate?
Seen more Imprezas fail the noise test at Bedford than any other car combined!
Old Dec 3, 2007 | 04:20 PM
foreigneRS's Avatar
foreigneRS
Testing the future
no rich, not standard. but not particularly loud either.
i will have a look on their website at what their limit is and how they measure it though, as we have the gear in work that i can use to do the same just to be on the safeside
Rstar_man
143
Jul 20, 2020 11:16 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
YODI
Aug 30, 2015 01:12 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
lockie
Jul 31, 2015 10:03 PM
