Gear ratio's for the Bara straight cut box.
Old Nov 26, 2007 | 02:35 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Gear ratio's for the Bara straight cut box.
Because of Dave's (YUM) high speed run it was realised that the Bara box might have a short 5th gear. I had been told that all the ratio's were standard, this is not the case.
I asked Bara for the tooth count on ALL the gears so that I could work it out myself. Here are the results:
1st 3.6
2nd 2.13
3rd 1.38
4th 1.00
5th 0.863
Alternative 5th gear is .812
Old Nov 26, 2007 | 02:53 PM
RANJ's Avatar
RANJ
awsome launch tho
Old Nov 26, 2007 | 02:59 PM
sunny's Avatar
sunny
Fair play for Martin for checking it all out properly.
Old Nov 26, 2007 | 03:49 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
So your not going to tell us the MPH per 1000rpm with your tyre size then with the old and the new ratio
Steve.
Old Nov 26, 2007 | 03:55 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Default Re: Gear ratio's for the Bara straight cut box.
1st 3.6
2nd 2.13
3rd 1.38
4th 1.00
5th 0.863
Thanks for confirming that Martin, its as I suspected on the day, so frustrating when it was assumed to be standard, Mark looked at me as if it was my problem that Dave was bouncing on the limiter. .
Old Nov 26, 2007 | 03:56 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Steve.
mph per 1000rpm is 7% higher on the new ratio .
Old Nov 26, 2007 | 04:00 PM
kitchy's Avatar
kitchy
RS2000 4x4
according to my mafs it will do over 200mph, now go try it!
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve.
Thats teaseing Rod
Steve.
Old Nov 26, 2007 | 04:01 PM
dave cos4x4's Avatar
dave cos4x4
are the other gear ratios different or is it just 5th gear.
why are they different?
Old Nov 26, 2007 | 04:03 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
May be a tad short on Power, im a realist I guess 197/198 ish, but Dave will be out to prove me wrong.
Old Nov 26, 2007 | 04:04 PM
Martin-Hadland
Steve.
Does not mean that it will pull it though but I'm sure we will see in due course...
Old Nov 26, 2007 | 04:06 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Steve.
Read the previous post Martin, like me you have been there a know it aint easy.
kitchy's Avatar
kitchy
RS2000 4x4
we will see, its not like i could actually do any calculations considering i dunno what top speed it did at the limiter with the old gear or what revs it was at
Old Nov 26, 2007 | 04:09 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Assuming 225/40 x 18 tyres, 8010rpm would equal 203.4mph with the taller fifth .
With the taller fifth, he only needs to pull 7747rpm to do the speed that would make YUM the fastest non-nitros powered Cossie .
Old Nov 26, 2007 | 04:20 PM
carlo's Avatar
carlo
What is the fastest non nitros,d cossie top speed just now mike?
Old Nov 26, 2007 | 04:24 PM
dave cos4x4
slightly bigger tyres then.
hope you do it Dave.
Old Nov 26, 2007 | 04:27 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Mike I can now work out what Dave did at Brunters from the info now on this site, wont belong before others do it .
Old Nov 26, 2007 | 04:29 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Cossie is still Martin, Cossie Powered is some Scottish mate that we cant talk about yet.
Old Nov 26, 2007 | 04:32 PM
Mike Rainbird
Caraholic
See Rod's comment and watch out for the Top Speed issue of PF .
Old Nov 26, 2007 | 04:49 PM
JamesH's Avatar
JamesH
So YUM did 190mph @ the thrash
Old Nov 26, 2007 | 05:41 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
i worked it out to 196.6, never was any good at maths
Old Nov 26, 2007 | 05:46 PM
carlo's Avatar
carlo
What was martins speed tho? i know about the scottish cossie mate
Old Nov 26, 2007 | 05:48 PM
Martin-Hadland
194.7 was the top speed that my old car made, think that was in June 2003.
Old Nov 26, 2007 | 05:58 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
.my pal has that gearbox........................fuckn noisey bastard it is..............(when the car works).he drives with earplugs in.............
Old Nov 26, 2007 | 06:09 PM
Martin-Hadland
That box might be noisy but it did the business for me
Old Nov 26, 2007 | 06:18 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
i always thought 5th was different in mine...now i know why
andrewg's Avatar
andrewg
i worked mine out to be 210 at 8200
Old Nov 26, 2007 | 06:25 PM
Martin-Hadland
What do you have? 0.80 ? Btw, well done!!
Old Nov 26, 2007 | 06:31 PM
andrewg's Avatar
andrewg
yip
Old Nov 26, 2007 | 06:32 PM
andrewg's Avatar
andrewg
i'm sure the rolling radius of the tyres increase at that speed
Old Nov 26, 2007 | 06:33 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
they will,but only a very small amount.
Old Nov 26, 2007 | 06:36 PM
andrewg's Avatar
andrewg
every little bit helps says the wee wumen that pished in the sea
Old Nov 26, 2007 | 06:47 PM
marco polo's Avatar
marco polo
Old Nov 26, 2007 | 06:49 PM
andrewg's Avatar
andrewg
Can you get it to pull 8200 in 5th then??
don't know miby find out next year
and its got 6 gears
Old Nov 26, 2007 | 06:53 PM
andrewg's Avatar
andrewg
and its 6th
Solid lifter time then?
cause mine is a race spec engine it has solid lifters and it loves reving
