2.0 Zetec into a Mk4 Fez???? Tekie help!!
a friend of mine want to put a 2.0 mondie lump into her Mk4 fezz.
Should be an easy swap, but has anyone actually done it? Flywheel will need changing but what about sumps? waterpumps?? anyone know?
Ask on FiestaTurbo.com mate. When I was thinking of doing this I had alot of help from people on there, but I can't remember the website addresses they gave me.... Others gave help over PM, so worth doing a post
id just use all the 1.8/1.6 escort/fiesta parts like they do in the mk1 and mk2 fiestas mate.
you'll need to change the water pump, sump, flywheel and altenator i think buddy.
wont go wrong using those bits anyway.
You might've already been given these two, but if you haven't...
http://www.fiestaturbo.com/zetecconversions/ (the better of the two
... aaaand...
http://fiftyoneCL.hopto.org/st2000/ff3engineswaps.html
To be honest mate it might be easier to fit the Focus 2.0L Zetec running Fiesta 130ps-spec management and inlet/exhaust manifolds because of the central engine mount the Foci use.
Best of luck!
/deckmunki
... aaaand...
Best of luck!
/deckmunki
... aaaand...
Best of luck!
/deckmunki
... aaaand...
Best of luck!
/deckmunki
The Enigma
Sep 29, 2015 10:31 AM
SMILER258
Sep 28, 2015 09:04 AM
