General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
thats with the wheels btw and the slicks are new(2 did 2 runs of santa pod today though, hence not Ł400, thats an expensive 2 runs!), there a hard compound at first and only get warm after a bit so should last better than normal.
3x14.2's, I should of done some big bad bwoy burn outs!,If you've got room under the arches get some Dunlop X04's in 15" second hand, put a wanted add on rallyusedparts.co.uk, they're a 55 profile though,loads of rally boys will have em, probably free if you pick em up.
Andy
X04 means hard, they go up to X14 which is super soft for use as a wet, 4's and 6's are best for track/Ł. You can get maxisports which are better than a road tyre, just, and last forever!X14's on the strip wouldn't last, but would stick mega, Demon Tweeks also sell a tyre softening brush on liquid, but I've never used it so can't say if it works or not?
