XR3I starting problem
Old Nov 23, 2007 | 08:56 PM
petermintrst's Avatar
petermintrst
Default XR3I starting problem
My car sometimes doesnt start when its hot.
I was told the battery wasnt good enough so i changed that to a heavy duty one, the engine turns over ok all the time so its not the starter. its as if no fuel is getting through or no spark, but when i leave it for a bit it nearly fires, but doesnt, then i leave it longer and it VERY nearly starts but doesnt, then i leave it even longer (cooler engine) and it fires up. no real rhyme or reason.
could it be fuel vaporisation? if so, how is this cured? bad timing? how is that cured.
i need to get this sorted as its annoying and mildly inconvenient to say the least
cheers all
peter
Old Nov 26, 2007 | 01:50 PM
XR2's Avatar
XR2
XR3i MFI (K-Jetronic)?
Looks like you've got the same problem like this guy. Just read my post on page 2:
https://passionford.com/forum/viewto...r=asc&start=38
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Dahl88
Aug 22, 2015 08:16 PM
stevierob
Aug 11, 2015 09:08 PM
Bloody-Fox
Aug 3, 2015 07:48 PM
