ofab or ofac
Open your passenger door, lay on the floor look to the heavens and under the dash board up behind the glove box you will find the ecu...
If its untouched there will be a plate covering the end with ofac or ofab code on it...
if this has been removed its been chipped at some time or maybe chipped still.
On the top of the ecu it will have the same code printed.
escort1989uk
Nov 23, 2004 09:41 PM
