Cambelt cover mounting posts
Old Nov 22, 2007 | 08:53 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Default Cambelt cover mounting posts
Can you still get these (the metal posts that raise the cambelt cover up from the rocker cover)? One of mine has sheered off and the front centre mount one that pushes the cover away from the block is missing. Cheers.
Old Nov 22, 2007 | 10:22 PM
mechanic28's Avatar
mechanic28
no chap i asked at fords a while ago,but should not be hard to get one off someone from ere
Old Nov 23, 2007 | 07:24 PM
Just buy some HEX bar of stailess steel, and get them turned up, should be cheap as quick easy job to do.
Old Nov 24, 2007 | 02:59 PM
Twellsie's Avatar
Twellsie
i had a bag with a few in, but after some searching have given up
martinmilne
Oct 18, 2019 02:18 AM
