Rear beam bushings problem
Old Nov 22, 2007 | 04:49 PM
xan_lee's Avatar
xan_lee
Default Rear beam bushings problem
Is this normal?Or must it be pressed to the floor? The car is jacked up.
Old Nov 22, 2007 | 05:03 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
looks a bit worn to me
Old Nov 23, 2007 | 09:43 AM
CosKev3's Avatar
CosKev3
Would of thought should beon the chassis rail at all times
Have you tried tightening the big bolt????
Old Nov 23, 2007 | 10:03 AM
coswol's Avatar
coswol
another pic
Old Nov 23, 2007 | 10:42 AM
coswol's Avatar
coswol
anyone have pics of it of your car?
Old Nov 23, 2007 | 01:23 PM
Remko GT's Avatar
Remko GT
It's not normal. The rubber should be all the way up to the chassis.
The beambush also appears a bit dry/worn.
How is the other side? The same?
I might be able to take a couple of piccies next weekend as soon as I'm working on my car again. Not sure though, might be next week before I get around to it. Busybusybusy
Old Nov 29, 2007 | 06:15 PM
coswol's Avatar
coswol
with the standart bushing i dont see how it can to it be up.
i have a set new of poyluretane and this are more high that the standar bushings
to put the news i need to remove all the rear beam?
Old Nov 30, 2007 | 11:13 AM
Remko GT's Avatar
Remko GT
Maybe not but in my experience it's kind of tricky to take out the original bushings out the beam even when it's off the car so I'd say, yes, the entire beam needs to come off.
When you fit the beam with PU bushes the bushes get compressed. That's where they get their rigidity from. That's also why it's so hard to get the bolt to catch in the chassis. Last time I fitted a polybushed beam I had to use a trolleyjack to push the beam to the car so we could get the big bolt catch the nut in the chassis.
Old Nov 30, 2007 | 12:37 PM
coswol's Avatar
coswol
http://www.protois.com/servlet/ShowI...FR24RFK3KFL1LF
Old Dec 4, 2007 | 03:04 PM
coswol's Avatar
coswol
now he is subject.
before, with standar bush it were absolutely impossible
Oct 9, 2015 07:38 PM
FlashRS
Sep 14, 2015 12:36 PM
Bosch
Aug 23, 2015 12:31 PM
155lee
Aug 14, 2015 11:21 AM
