Sapph front bumper
The front bumper on my newly acquired Sapp appears to be sagging and loose on one side. Is this a common fault and how easy is it to remove the bumper and replace fixings etc?
Thanks.
Thanks.
had the same problems myself heres how i fixed mine
remove the bumper drill out the rivets that hold the bracket on both sides out
get the following large washers say 40mm(4No) with 6mm hole m6x60mm long bolts(2no) and nuts(4no)
(got mine at B&Q
put the bolt thr one of the washers and put the through the backside of the bracket and place the bracket back onto the bumper and re rivet the bolt will be held there and can then pass through the openong on the car just under the wing.On the inside this place another washer and then bolt up tight add another bolt to act as a locknut
The other side is the same but dont forget to rivet both in place before fitting the bumper
I hope this is clear if not let me know
(got mine at B&Q
(got mine at B&Q
(got mine at B&Q
This does seem to be a common problem with the sapphs, don't think there is anything you can do with the middle of the bumper sagging though, would like to know if you can as mine has started to sag now.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
