wheel PCD
Old Nov 21, 2007 | 08:23 AM
saph in dorset's Avatar
saph in dorset
Default wheel PCD
is there any way to get the probe wheel hub to fit on a sapph as i have found some wheels and they only come in 5x114 and am led to believe so is the probe.
also i do not really want to change the discs etc so anyway without changing them.
Old Nov 22, 2007 | 09:51 AM
PAUL S's Avatar
PAUL S
Your one option is to change your hubs to granada 5 stud x 110 then use 5 stud hub adapters to go from 100 to 114
I doubt the probe hub will fit as its originally a mazda part
Old Nov 22, 2007 | 01:44 PM
Ridgey's Avatar
Ridgey
Probably cheaper and easier to get some correct pcd wheels.
Old Nov 22, 2007 | 02:06 PM
mcerd1's Avatar
mcerd1
the granada hubs have a 5x112 PCD (not 110) with the same 63.4mm centre bore as the sierra
I can give you some info on swaping to granada hubs if you want (without changing the struts)
I'd agree that it will be cheaper and easier to get wheels that fit either the sierra or granada
Old Nov 22, 2007 | 02:29 PM
sarnyboy69's Avatar
sarnyboy69
if the granada is 112 and the wheels are 114, you wight be able to use 'wobble bolts' ??
Old Nov 22, 2007 | 09:39 PM
saph in dorset
thanks you guys just confirmed what i thought.i do not really want to change the hubs as it involves changing too much stuff and would be cheaper to get the correct wheels
Old Nov 23, 2007 | 12:30 PM
Dave McB's Avatar
Dave McB
A PROBE IS BASICALLY A MAZDA MX6.
Its jap, so the wheel stud pattern will be 5x114.3
Id debate anythin from the ford stable would fit.
Cheaper to get right wheels than attempt swaps.
On a positive note, the wheels will be easy to sell as ur wheels will fit all jap cars with 5 stud wheels
Old Nov 23, 2007 | 01:20 PM
Remko GT's Avatar
Remko GT
Swapping to 5x112 gives you a lot more choice in wheels though.
We swapped to 5x112 on my Sierra because I wanted OZ ST but couldn't get the proper ET on 4x108. On 5x112 you can also get wider wheels. The The OZ's I bought for instance are 8x17, maximal width on 4x108 is 7,5x17. I could've swapped carriers but then I would have had to block the ABS sensor hole and buy different shocks. Didn't want to do that because I just had bought brand new adjustable Koni's
My m8 modded the Sierra carriers to accept the bigger Granada wheelbearings and thus the 5x112 hub. My Sierra isn't a (real) Cossie though so I'm not sure you need to swap wheelbearings in a Cossie carrier to be able to fit the Granada 5x112 hub.
Old Nov 27, 2007 | 05:13 PM
mcerd1's Avatar
mcerd1
My uprights arn't cossie ones either - I had the Granada hubs turned down to fit the sierra bearings instead
the only problem the 5 stud conversion gives you is the brakes
std ABS/ V6 type sierra calipers are the same as the granada ones, apart from the offset and the number of studs - so you need 5mm spacers and longer bolts for the calipers
Audi and Merc wheels are also 5x112 but have different centre bores and Audi's use 14mm studs/bolts
Fiddy
21
Sep 29, 2015 06:10 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
