battery drain!
Old Nov 19, 2007 | 06:23 PM
mr_intex's Avatar
mr_intex
Default battery drain!
i have tried to find the battery drain today and when i was connecting the multimeter on the negative and positive of the battery it was showing 0.00 on the drain.
i can't understand that.
then the battery didn't have enough power to start the car again a few hours later so it was draining.
help!!!
thanks
Old Nov 19, 2007 | 08:48 PM
CosKev3's Avatar
CosKev3
Presume you have tested battery?????
And its right size for car????
Old Nov 19, 2007 | 10:13 PM
mr_intex's Avatar
mr_intex
have had 3 new batteries on the car now!
Old Nov 19, 2007 | 11:25 PM
jon@work's Avatar
jon@work
If the meter was set to measure current, you need to connect the meter in series, not in parallel. Disconnect the earth strap and put the meter between the end of the earth strap and the battery negative, if you didn't.
Old Nov 19, 2007 | 11:34 PM
mr_intex's Avatar
mr_intex
i will try that tomorrow jon.
thanks
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
