Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
racing puma stuck in gear!
Old Nov 19, 2007 | 09:38 AM
cossie_love's Avatar
cossie_love
Default racing puma stuck in gear!
hi
my friend has a racing puma and it seems to be stuck in third gear!
the clutch still works but it just wont come out!
i checked the linkage under the car and that seems to be fine
does anyone have any idead's?
or is it a comman fault?
Old Nov 19, 2007 | 12:01 PM
Dal_'s Avatar
Dal_
Not a common fault no!
is it different if it's hot or cold?
My gearbox almost seized last year when the prat that owned it before me must have kept crunching reverse in. Binds up the 1st gear to housing gap and makes it appear siezed. Worse when hot.
Old Nov 19, 2007 | 12:21 PM
cossie_love
it seems to be stuck in 3rd and i cant get it out even if its hot or cold
might just fire to it!
Old Nov 20, 2007 | 03:35 PM
AlexF's Avatar
AlexF
gearbox has failed...
Alex
Old Nov 20, 2007 | 03:47 PM
Paulo P's Avatar
Paulo P
Alex
Yep, I killed 2 gearboxes on my old 1.7 puma by being "enthusiastic" I killed more clutches than boxes though
Old Nov 20, 2007 | 04:31 PM
xr-stu's Avatar
xr-stu
fucked.
Old Nov 20, 2007 | 05:59 PM
MATT222's Avatar
MATT222
reverse gear idler breaks up inside the gearbox (not using the 5 sec rule when putting in reverse) causing the selector fork to jam on the gearbox
casing!!! seen loads!!!
hope that helps matt
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
The Youth.
Sep 30, 2015 09:59 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
