Saff 4x4 gearbox whine
Nov 16, 2007 | 05:11 PM
Hi there all. Ive got a whining noise in first gear when im pulling away put the rest of the gears are ok. What causes the noise. Do you think if i change the gearbox oil it will make a difference. Or is the gearbox fooked.
Nov 16, 2007 | 05:30 PM
Resident Wrestling Legend
make sure there is the correct oil in there first
it's specific for the mt75 and it's not the same as what ford now tell you it is
Nov 16, 2007 | 07:41 PM
may just need a top up or new oil,if its fooked i have an mt75 from a 4x4 for sale
Nov 17, 2007 | 07:57 AM
What grade of oil do u use in them. Can you use 75/90 semi synthetic. If not what is the special oil that people use then.
Nov 17, 2007 | 09:48 AM
I used 75/90 synthetic stuff and the box whined so put ford stuff back in and it was fine again.
Nov 17, 2007 | 03:08 PM
Sweet what is the ford oil you used then.
Nov 17, 2007 | 03:13 PM
I cant remember m8 i know it's specific for the mt75.
Nov 20, 2007 | 10:51 PM
Castrol FMT if I recall. Specifically for ford boxes.
Nov 21, 2007 | 06:46 AM
I will have to have a look up at the ford dealer and see if they can get me some.
Nov 21, 2007 | 08:39 AM
Castrol SMX-S available from the ford dealer
Nov 23, 2007 | 02:02 PM
It's available from ford I have a couple of bottles spare (not for sale). Its called
MT75 5-speed transmission oil, and that's exactly what it says on the bottle. White bottle blue print and writing DONT PUT ANYTHING ELSE in it.
hope this helps.
Nov 23, 2007 | 06:06 PM
Thanks very much people i will make a note of it and try and get some. Does anyone know which ones are the drain and filler hole.
Nov 23, 2007 | 06:20 PM
erm drain is the lowest and fill its the highest. needs a torx bit if I remember right. It's the torx screw at about 1pm on a clock if your looking at the box from under the car towards the front.
Nov 23, 2007 | 06:31 PM
Nov 23, 2007 | 07:47 PM
there was a topic just like this only the other day with pics and stuff on it
everything is visable from the passenger side
Nov 24, 2007 | 09:20 AM
Sweet thank you. I will have a look when i put it on a ramp at work.
mjonathan24
Oct 29, 2015 10:39 PM
cossie330
Oct 7, 2015 08:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Ronnie Scott
Sep 20, 2015 10:21 PM
Adam Graham
Sep 6, 2015 06:04 AM
