AFR
Old Nov 15, 2007 | 10:26 PM
Miller 3's Avatar
Miller 3
Default AFR
Do i have to run a seperate lambda sensor for a AFR gauge
Old Nov 16, 2007 | 07:18 PM
Miller 3's Avatar
Miller 3
Old Nov 16, 2007 | 07:46 PM
Tev's Avatar
Tev
Default Re: AFR
im runnin 2 1 for the gauge n 1 for closed loop
Old Nov 16, 2007 | 08:11 PM
Miller 3's Avatar
Miller 3
Tev
Thanks mate' That's what im just sorting out
Old Nov 16, 2007 | 08:21 PM
Tev's Avatar
Tev
Tev
I would assume that u could use just 1 as from what i can c they r really simple, the lamba 4 closed loop is only 3 wires 1 sender n 2power/earth, but then again my AFR gauge came with its own lamba
Old Nov 16, 2007 | 09:02 PM
Miller 3's Avatar
Miller 3
Looking at one of these...
Old Nov 16, 2007 | 09:14 PM
Tev's Avatar
Tev
Does that come with its own lamba sensor?
this is what ive got
Old Nov 16, 2007 | 09:18 PM
Miller 3's Avatar
Miller 3
Yes but i think you have to buy the Thermocouple sensor separately for the EGT
http://shop.vems.hu/catalog/product_...roducts_id=101
Old Nov 16, 2007 | 09:35 PM
Tev's Avatar
Tev
All the connectors to make it work (WBO2 connector, supply, fuse)
Looks the part n is cheap enough
This is a good gauge
http://cgi.ebay.co.uk/Innovate-Motor...QQcmdZViewItem
Old Nov 16, 2007 | 09:46 PM
Miller 3's Avatar
Miller 3
I like the VEMS as it has EGT aswell as AFR in the one gauge... Is there any others like that
Old Nov 16, 2007 | 10:06 PM
Tev's Avatar
Tev
Pass im not 2 sure fella
Old Nov 17, 2007 | 02:01 PM
Miller 3's Avatar
Miller 3
Any one else
Old Nov 17, 2007 | 06:06 PM
garrett-killer's Avatar
garrett-killer
i use my innovate LC1 set.
it has 2 analoge out- 1 for the gauge and 1 for the ecu.
you can programm how you like it.
i programmed 1 out to 0,5volt@ lambda 0,5
and 1,5volt@lambda 1,5
so i can use a cheap voltmeter.
with the 2nd you can play and set your lambda settings how you like.
you can disconnect your stock one.
cost ~150pounds.
Old Nov 20, 2007 | 09:00 PM
Miller 3's Avatar
Miller 3
up
Old Nov 20, 2007 | 10:32 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
dont confuse a narrow band with a wideband..........
Old Nov 21, 2007 | 03:57 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
This tells you all
http://www.turbobits.co.uk/acatalog/...tio_gauge.html
Old Nov 21, 2007 | 04:23 PM
Cosworth Bassie's Avatar
Cosworth Bassie
Yes, Zeitronix.
Chas
Oct 5, 2015 07:13 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Marino
Sep 12, 2015 11:10 AM
Red_bull
Aug 25, 2015 06:27 PM
Fiecos Dan
57
Oct 22, 2006 09:18 PM
