2wd cosworth diff ????
Old Nov 15, 2007 | 08:33 PM
coley's Avatar
coley
Default 2wd cosworth diff ????
recently the diff on my 2wd has started to grumble a bit when its on over run? there is no wine or any noise wile it is under load, now i a gussing that this is a worn bearing? is it posible to replace just a bearing set or is it posible it could be something more serious?? if i went to a quaif diff would this solve the problem or would i still have the grumbeling on over run? if i fitted the quaif on its own ? thanks guys any help will be great
Old Nov 15, 2007 | 10:25 PM
Sideways_Sierra's Avatar
Sideways_Sierra
have you checked the prop bearing about half way down the car, 2 bolts holding it on, see if you have any play in it
Old Nov 16, 2007 | 03:37 PM
coley's Avatar
coley
ive been under the car today and give it a good wriddle but it dosent seem to have any play at all ?
Old Nov 16, 2007 | 06:42 PM
Sideways_Sierra
happened in my transit thats all
you could have play in the diff, best to jack the back end of the car up and turn the shafts, including prop and see where the play is
if no play, then it'll be internal, so rebuild time
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
