Heated screens
Old Nov 14, 2007 | 09:20 PM
rallyeweezle's Avatar
rallyeweezle
Default Heated screens
The front and rear heated screens in my car are not working, does anyone have an idea what it could be. The light on the rear switch comes on but not the front im at a loss any help will be much appreciated.
Dan
Old Nov 14, 2007 | 09:21 PM
KSA-Cossie's Avatar
KSA-Cossie
Bad earth or fooked relay .
Old Nov 15, 2007 | 04:32 PM
rallyeweezle
Do you have any idea on the relay number? I did not get an owners manual with the car
Dan
Old Nov 15, 2007 | 04:33 PM
KSA-Cossie's Avatar
KSA-Cossie
They're located behind the glovebox m8.
Old Nov 15, 2007 | 04:36 PM
dojj's Avatar
dojj
Resident Wrestling Legend
won't be a number, it'll be in the loom somewhere if it's the front screen, possibly under the passenger side glovebox but think more along the lines of behind the centre air vents
Old Nov 15, 2007 | 04:43 PM
rallyeweezle
Sounds like fun ........ not
Old Nov 15, 2007 | 07:05 PM
xr4x4x24's Avatar
xr4x4x24
I drive a Volvo!
Default Re: Heated screens
Dan
Is the light on all the time? mine is, I've found if you hold the button in, the rear screen works! (Yes, I have change the relay, still the same) It may have some to do with the radio booster in the tailgate, as the power to the screen runs through that box
Old Nov 15, 2007 | 11:14 PM
rallyeweezle
With mine the light for the rear works fine and I can hear the relay click but the front does nothing, I will have to get my multi meter out as this is now becoming a pain in the ass.
Old Nov 16, 2007 | 04:46 AM
stevecossy's Avatar
stevecossy
On my last car it was the relay. But on my car now its a bigger problem, it not work because some tight t#at has replaced the screen with a none heated 1. Think ins claim may av to go in lol
Old Nov 16, 2007 | 06:14 AM
KSA-Cossie's Avatar
KSA-Cossie
Check you have power at the switch m8,haynes manuals do the wiring diagrams.
Old Nov 16, 2007 | 11:47 AM
dojj's Avatar
dojj
if you can pull the switch out you can use aontoerh switch with one of the poles broken off as they are all the same fitment, just with different protrusions on them to make them only fit one way in
so swap the switches over and see if this makes a difference
Old Nov 17, 2007 | 07:42 AM
rallyeweezle
Cheers for all your help
Dan
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cossie09
Sep 10, 2015 06:56 PM
