HELP - Any Ideas??
Old Oct 8, 2004 | 03:46 PM
gary scott's Avatar
gary scott
Default HELP - Any Ideas??
My RS Turbo is blowing oil out of the dump valve!!!
It is a low comp 1.8 ZVH and is running 140psi across all four cylinders and has an oil seperator tank aswell.
Does not appear to be be smoking and the oil cap seems to be staying on aswell!
Any suggestions what might be causing it??? Could the cylinder head cause this or even the turbo??
Would take it somewhere but its out of MOT!!!
HELP!!!!!
Old Oct 8, 2004 | 03:48 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Turbo seals fucked.
Wont be the engine if its coming out the dumpvalve, the dumpvavle is BEFORE the engine in the route
Old Oct 8, 2004 | 03:55 PM
gary scott's Avatar
gary scott
There doesnt seem excessive play in the shaft tho?? Could it still mean the oil seals are fucked tho??
Old Oct 8, 2004 | 03:59 PM
boost mad's Avatar
boost mad
yeah same happened on my cossie turbo im afraid. unless ( not sure on cvh ) but do u have a breather return to the air filter? if that pissing in oil then i cud be but i very much doubt it!
Old Oct 8, 2004 | 04:07 PM
gary scott's Avatar
gary scott
I do have a breather return to the air filter but its via a oil seperator tank.
Any other ideas??
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fezman1
Oct 2, 2015 01:22 PM
Orion_Gav
Sep 29, 2015 04:50 PM
rogerxr3i
Sep 13, 2015 06:56 PM
