Mk3 Fiesta Door Removal?
Old Nov 13, 2007 | 12:36 PM
XRT_si's Avatar
XRT_si
Default Mk3 Fiesta Door Removal?
Has anyone found an easy way of removing a mk3 fiesta door? I hear there is a tool to remove them? Or can I just knock the pins out and is there a trick to this as I didnt get that far
Thanks
Old Nov 13, 2007 | 12:48 PM
xrsi's Avatar
xrsi
grind the door hinges off the shell!
Old Nov 14, 2007 | 04:56 PM
Turboboy67's Avatar
Turboboy67
My local body shop has a chisel with a v cut out the end,
I borrowed it and had both the doors off on my old RS1800 within 5 minutes.
Old Nov 22, 2007 | 04:26 PM
mike2530's Avatar
mike2530
Sykes Pickavant do a hinge pin removal tool and it works brilliantly and only about £15
Aug 29, 2015 08:16 PM
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
leep27
Ford Mondeo Including ST
Aug 22, 2015 01:52 PM
Bosch
Aug 4, 2015 05:14 PM
no1trancefan
Aug 4, 2015 12:48 PM
