what dump valve for a cosworth?
as title,what is the best dumpvalve?i have a 2wd standard sapphire,in the future i will be buying a big spec engine with bigger turbo etc,but im not sure what dump valve to get in the meantime?all the jap 1s sound crap,they whistle.baileys are too hissy,collins are still dumping after you change gear and are too poor sounding,my pal had a 4x4 sapph a few years ago and when he changed gear at full boost his sounded like a whip cracking followed by a nice noise,whhhaaaaaatooooooshhhhh,say that quickly and you will get an idea!!!ha ha,cheers.
You either love em or hate em
as you can see by one of the replies above
I would say go for a Graham Goode diaphram one, get the right spring in it and it gives it the long puutsssssssshhhhhhhhh
Luciano
Luciano
does everybody mean the£325 group a dump valve or another ggr 1?seems a bit steep for a dump valve thats i am just buying for the novelty factor!cheers guys.
hi,just checked,i put in ggr 101 and that comes up cosworth dump valve,£324,well thats for the dump valve relocation kit.the ggr 110 valve is £176.25,so ill get 1 ordered this week,will any fitting kit do?also i take it the you only need 1 blanking plug and that goes into the top of the cooler?ta,lee
got it all orderded from ggr,the blanking plug was £5.88 so i just bought them both at the same time,im getting the fitting kit from santa if im good so ill get it fitted before the new year!thanks,lee
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
rsstav
Aug 11, 2015 04:22 AM
