How the Fcuk does this happen? - CV Boot
Old Oct 8, 2004 | 01:08 PM
St3V3_C's Avatar
St3V3_C
Default How the Fcuk does this happen? - CV Boot
Both clips are still on, it has sprayed grease everywhere and looks like it's all twisted up?
How? Why?
Old Oct 8, 2004 | 01:10 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
looks like all the air has been sucked out it
Old Oct 8, 2004 | 01:49 PM
JohnnyB's Avatar
JohnnyB
fooking odd
Old Oct 8, 2004 | 01:51 PM
AlexF's Avatar
AlexF
is it split at all?
Old Oct 8, 2004 | 01:54 PM
MadMac's Avatar
MadMac
whitneyd's Avatar
whitneyd
If it's on an Escort Cos it's because more than likely your engine mounts are shot. So when you engine torques it tries to pull the CV apart slipping the boot off enough to let some of the grease out then the engine settles and pushes the boot back on. This happens when the straps aren't tight enough and I believe one of yours looks like a zip tie. That's a no no.
Old Oct 8, 2004 | 01:57 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
should it not be over the lip aswel??
Old Oct 8, 2004 | 02:00 PM
discodenkelly's Avatar
discodenkelly
bounce, bounce, bounce
That picture looks familiar, although mine has a huge split in it
Old Oct 8, 2004 | 02:02 PM
whitneyd's Avatar
whitneyd
Two different lips.
Old Oct 8, 2004 | 02:09 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ah, right o
it is an esc cos btw
Old Oct 8, 2004 | 02:10 PM
St3V3_C's Avatar
St3V3_C
You might be on to something there - but I am wondering (looking at the pic) if the boot is rubbing on the chassis leg, rather than the clip being pulled off then put back on. They are tight and I just don't think it would go back on. Perhaps the small one could move, but it looks like the grease is from the big end.
Old Oct 8, 2004 | 02:14 PM
St3V3_C's Avatar
St3V3_C
Is it rubbing here?
Old Oct 8, 2004 | 02:16 PM
cossiestu's Avatar
cossiestu
I had the same thing on mine. Both my engine mounts were shot! Had a really violent vibration thru the car, too....
Old Oct 8, 2004 | 02:18 PM
St3V3_C's Avatar
St3V3_C
Old Oct 8, 2004 | 02:27 PM
GARETH T's Avatar
GARETH T
i bet if you take your engine mounts off,, they are ripped in half
been there done it
Old Oct 8, 2004 | 02:37 PM
DOO's Avatar
DOO
You not getting anymore cv boots under warranty now
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
mk1turboestate
Dec 2, 2015 08:31 PM
chris m1
Sep 7, 2015 08:02 PM
