Advice Needed
Old Oct 8, 2004 | 12:47 PM
Boozehound's Avatar
Boozehound
Default Advice Needed
Guys,
Have been putting my Saph 4x4 in the same garage for ages. On the way home from a long journey though my front passenger side wheel bearing gave up the ghost and I had the car delivered to another garage who I asked to go over it with a fine toothcomb and gimme a report. Turns out my old garage was no use! Leaks from the gearbox, an oil leak, power stearing leak, front passenger side hub and associated bits gubbed, rear suspension tie bars gubbed, welding needed under the driver side.
Basically I need a load of work done, which the new garage will do for me. The problem I have is that they can't get a hold of the parts needed and Ford were as much use as a chocolate teapot.
Any suggestions?
Cheers!
Old Oct 8, 2004 | 01:03 PM
TILLIO's Avatar
TILLIO
List the parts in wanted section, one of the breakers or "someone" on the forum will/should have the parts you need
Old Oct 8, 2004 | 01:06 PM
mattbibs's Avatar
mattbibs
do you trust this new garage tho? they proably will be fine but its always worth checking out!
Old Oct 8, 2004 | 01:09 PM
foreigneRS's Avatar
foreigneRS
Testing the future
or maybe your old garage was good and this one says it all needs doing when it don't really to make a quick buck?
rear suspension tie bars? what is that supposed to mean? did they say that? if so, they wouldn't appear to know much as a sierra doesn't have them - it has semi-trailing arms.
Old Oct 8, 2004 | 01:13 PM
Boozehound's Avatar
Boozehound
Nah, the guy took me under the car and pointed out everything that was wrong. I know enough to get by and could tell it was gen up. Plus the fact it's my old boy's mate.
Michael Wisbey
Aug 14, 2015 11:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
