Are XR4x4 FRONT calipers the same as 4x4 saph ones?
lol,
fronts....
front mounting lugs are different between the two calipers,so they won't fit.
rears....
all the same, even the pads on the 2wd will fit 4x4 rear calipers.
fronts....
rears....
As above - the calipers for the rear 4x4 are only the same as the 2wd rear saph. Also note that the discs are different sizes to the rear even then so the mounting points must be different (though the caliper may be the same)
JJ
JJ
the short answer:
no
and no
for the fronts and the rears
the long answer:
the offsets on the front plus the design of the hub are all different so no, they won't fit on the front
the rears "will" fit as all sierar/granada solid discs use the same caliper
in the same way that all vented rears use the same caliper (4wd cos/granada/scorpio cos/granada,scorpio estate) but the moutning points on the bearing carriers are different on the cos versions and different again on the frog eyed scorpio versions
no
and no
the long answer:
jason_nike
Aug 18, 2019 10:53 AM
