Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
how hard to cossie a mk2
Old Nov 11, 2007 | 10:55 PM
Alps Pacino's Avatar
Alps Pacino
Default how hard to cossie a mk2
Jt wondering how hard it would be and what was needed to convert a standard rs2000 to accept cossie running gear.
I know you need a new transmission tunnel and aparently you need to 4 link the rear end? but i aint sure what the fuck 4 linking is tbh
Old Nov 11, 2007 | 10:57 PM
dave cos4x4's Avatar
dave cos4x4
very easy to do it.
but expensive to do it properly.
Old Nov 11, 2007 | 10:58 PM
dave cos4x4
4 linking is where it has 4 mounting points,2 on the car and 2 on the axle.
better to 6 link it like mine.
Old Nov 11, 2007 | 11:00 PM
xxshepxx's Avatar
xxshepxx
nobody done a how to guide? or a project thread sorta thing?
plenty of them about
Old Nov 11, 2007 | 11:01 PM
Alps Pacino
realistically how much you looking to do 1 and who can 6 link the back axle and for how much?
I might be able to get a supposedly mint rs2000 flat front with tarmac arch's for 2600 which has got me temted tbh
Old Nov 11, 2007 | 11:03 PM
dave cos4x4
plenty of projects getting done.
plenty of 'how to' guides too on turbosport forum.
Old Nov 11, 2007 | 11:04 PM
Alps Pacino
i'll have a look on turbosport
JonnyBravo's Avatar
JonnyBravo
You wont see any change out of 10k
Infact depending on what route you go down with you will be lucky to see any out of 20k
The Youth.'s Avatar
The Youth.
you don't have to do the back end mark, an lsd is advicable, but you can get away with the standard stuff, it works just not aswell as a 5/6 link setup
steve
Old Nov 11, 2007 | 11:05 PM
dave cos4x4
Alps Pacino
bite his arm off if you can get it for that!
you will need a decent axle to take the power...Ł1500-Ł3500 depending on spec etc..
4 link will do depending on what you will be doing with the car.
Old Nov 11, 2007 | 11:06 PM
dave cos4x4
very true.
Alps Pacino
JonnyBravo
How can it be 20k you can get engine loom box all ancileries for 4k MAX, ye if you want 500bhp 20k but i'm on about stg3 MAX
dave cos4x4
steve
well it won't last very long Steve.
Old Nov 11, 2007 | 11:08 PM
dave cos4x4
Originally Posted by Alps Pacino
JonnyBravo
depends what bits you fit.
Ł800 for a pair of Bilstein fron struts alone.
it all adds up...i know.
SS1's Avatar
SS1
the green 4*4 was the dogs
got no pics not on my home pc
anybody got them to hand
car was awesome
Alps Pacino
dave cos4x4
So 2600 is cheap for a flat front with a set of brand new mini lites and all the original engine etc to go back in it?
I might just get it and put the rs2k motor in and have it as a standard rs2k tbh
Old Nov 11, 2007 | 11:11 PM
JonnyBravo's Avatar
JonnyBravo
JonnyBravo
Best you go and get some prices on having a shell done properly then
Shell can be anything upto 10k painted
Axle 1k-4k
Engine and box Ł1500 to ?
Other bits - 1k to ?
Wheels, suspension, seats, tanks,
Even with a cheap shell, and I mean cheap I doubt you'll see any change out of 10k for a useable Mk2 Escort
Old Nov 11, 2007 | 11:12 PM
dave cos4x4
Alps Pacino
very cheap for a RS2000 in good condition.
take a look on ebay.
this one started off at 4k.
http://cgi.ebay.co.uk/FORD-ESCORT-MK...QQcmdZViewItem
or, if you want a decent shell.
http://cgi.ebay.co.uk/Ford-Escort-MK...QQcmdZViewItem
thats why the cars are worth so much.
Old Nov 11, 2007 | 11:13 PM
JonnyBravo's Avatar
JonnyBravo
JonnyBravo
Shall we add up what your shell cost to buy, then fabrication then paint and minus that from 10k ?
I bet there isn't that much change
Old Nov 11, 2007 | 11:17 PM
Alps Pacino
dave cos4x4
I dont want a full on monster just a cossie powered mk2 300bhp ish, i was under the impression the shells were decent enough and didnt need 10k spending on them to make them accept a cossie motor or am i missing something?
Old Nov 11, 2007 | 11:18 PM
dave cos4x4
JonnyBravo
don't remind me.
Alps Pacino
if you get a bit of time have a look at mine that i'm doing and try to work out what things you might need and what things cost.
https://passionford.com/forum/viewtopic.php?t=239961
still no where near finishedas far as spending goes.
Old Nov 11, 2007 | 11:23 PM
dave cos4x4
dave cos4x4
the shell will be not strong enough,there too old and will need strengthing up,hence the cage etc..
you need a decent axle with uprated shafts,lsd,brakes etc..., decent susp,brakes,fuel suppy, the intercooler/radiator is Ł1k plus from Pro-Alloy.
i suppose you can do it cheaply, but you still need the car/parts to cope with the power etc...
it will be worth it in the end as the cars are fetching stupid amounts of money.
Old Nov 11, 2007 | 11:25 PM
JonnyBravo's Avatar
JonnyBravo
The problem is how decent is it
Its quite hard to find a genuinelly alright shell, I paid top money for one, then had it dipped and luckily it was as solid as advertised.
Scrote (The original) with the black RS2000 had 400hp on a what I believe was a standard RS shell, I know its been well messed with this year but his certainly was proof that you can do it on smaller budget.
I suspect he had it all linked up for a good reason now though.
I even think he was running or still is running a Atlas with original shafts etc.. just chopped down obviously.
Old Nov 11, 2007 | 11:26 PM
JonnyBravo's Avatar
JonnyBravo
Dave - Are you using the Pro Alloy setup too then ?
Old Nov 11, 2007 | 11:30 PM
dave cos4x4
a lad i knew had a mk.1 on stadard rs2000 running gear with the cosworth engine,he done a track day and it was not very good as it was only driving one wheel at the back as there was no lsd.
his was about 250 bhp iirc, but he never really drove it in anger,if he would of had,then things would of broke.
you can do the conversion cheap,yes, but if you want to drive it proper,the main reason for fitting the engine then you will need the decent parts for it.
deffo buy that car though if its a decent one.
Old Nov 11, 2007 | 11:31 PM
dave cos4x4
fook that!
Radtec set up for me, think its about Ł600+ vat.
Old Nov 11, 2007 | 11:32 PM
Gaz 88's Avatar
Gaz 88
dave who did the fab work on your shell? do they do focus cossie conversions eg new tunnel?
thanks
Old Nov 11, 2007 | 11:33 PM
Alps Pacino
I'll have a look at it and see what the crack is, for all i know it might be a wreck.
Old Nov 11, 2007 | 11:35 PM
dave cos4x4
Gaz 88
Gaz, his name is Paul and he worked for Gartac for over 20 years,he does all types of conversions too.
maybe Andy Gallager or Steve Scott may be better fora focus conversion as they both have done it plenty of times.
JonnyBravo's Avatar
JonnyBravo
Alps - Picture of 6 link setup
Old Nov 11, 2007 | 11:36 PM
dave cos4x4
you would be surprised what the 'wrecks' get on ebay.
Old Nov 11, 2007 | 11:37 PM
JonnyBravo's Avatar
JonnyBravo
fook that!
Guess what idiot blew a months wages on the Pro Alloy one
Its made a nice ornament for the past 12 months though
Old Nov 11, 2007 | 11:38 PM
Alps Pacino
So where are the 6 links i can only see 2 bars running down the car and 2 running cross it from the diff?
JonnyBravo's Avatar
JonnyBravo
Sold my old wreck of a shell for 1k on ebay
Gaz 88's Avatar
Gaz 88
Gaz 88
cheers mate i have been in contact with andy just looking into all options
Thats why his fab work looks like it does then working for gartac for 20years..!
Old Nov 11, 2007 | 11:39 PM
JonnyBravo's Avatar
JonnyBravo
The picture doesn't show the 2 top link bars.
The axle has bars on top of it too
Old Nov 11, 2007 | 11:41 PM
dave cos4x4
JonnyBravo
pmsl at the ornament.
do the water pipes fit ok on the rad,they look too 'curled' to me in thier pic.
Gaz 88
Old Nov 11, 2007 | 11:44 PM
JonnyBravo's Avatar
JonnyBravo
They all fit fine so I'm told mate, I did query this when I spoke to Pro Alloy.
My only worry is that the IC isn't the biggest, they claim its good upto 600hp which I'm not convinced about, thank god for nitrous as I'm not buying another
Old Nov 11, 2007 | 11:45 PM
dave cos4x4
the bars get mounted to the body,you need to get these mods done so the bars will fit.
oh, a bigger diff tunnel too.
thats the top view.
under side.
JonnyBravo's Avatar
JonnyBravo
A Mk2 worth wanking over :
