4x4 cosworth calipers and 2wd discs
You will need a spacer bracket.
Get them from this man: Mike Rainbird - mike@rjpipe.demon.co.uk
I think you use 2wd discs and 4x4 calipers though.
You will need the 2wd discs and 4x4 calipers , they fit straight on , the only thing you may need to do is file the inside of the calipers as the outer edge of the discs may rub
Youonly need the spacers from Mike R if you intend to run S2 calipers and 2wd discs NOT IF YOU USE 4x4 CALIPERS
YOU DON'T NEED TO FILE ANYTHING TO FIT 4x4 CALIPERS AND 2WD DISCS
You eed to ADD 1mm spacers to get them to fit... Fitting guid link is down - will post later
This is the correct answer in my experience
Another bit of advice - if you haven't bought a set of 4x4 calipers yet - don't.
Instead get a pair of the brackets from Mike R's ite, (most likely cheaper at £40 than a pair of calipers) and the S2 calipers, when used with 2WD discs gives about 5% more breaking power than the 4x4 calipers anyway (down to pad size/design)
jason_nike
Aug 18, 2019 10:53 AM
Aug 14, 2015 07:29 AM
