xr4 cossie
Old Nov 9, 2007 | 10:42 PM
XRSTI's Avatar
XRSTI
Default xr4 cossie
puttin a 330bhp cossie lump in me xr4 but me gearbox mount aint the same it wider on the t5 will an xr4 box mount fit the t5??
Old Nov 10, 2007 | 08:21 PM
mechanic28's Avatar
mechanic28
cossie4i your man to ask
Old Nov 12, 2007 | 07:25 PM
XRSTI's Avatar
XRSTI
cheers
Old Nov 12, 2007 | 10:11 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I modified the XR4i mount to fit, otherwise you have to weld the car up to use the cossie mount.
Steve.
Old Nov 13, 2007 | 01:47 AM
xr4man's Avatar
xr4man
hahaha, you need to look to the american merkur guys. we are the masters of putting a t-5 into a sierra (merkur) shell. you can check out rapidogroup.com they make a mount specific to mounting a t-5 under a merkur. i have one on my car and it fit perfect.
i think BAT inc has them too, but not sure.
or you can get on merkurclub.com or merkursportcom and look for a user galaxie1. he makes mounts as well.
Old Nov 13, 2007 | 12:01 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
why make work for yourself when theres a std ford cradle that will fit straight on to the car with no mods
I think I've got one on the shelf at my unit.
Old Nov 13, 2007 | 12:39 PM
xr4man's Avatar
xr4man
but didn't cossie4i say that the car would have to be modified to use the t-5 mount? or the t-9 mount would have to be modified?
unless you are talking about yet a different mount.
Old Nov 13, 2007 | 01:22 PM
Dan@Rapid-Ford
yup, he did say that, and he said it to me when I converting my 4i.
but I used a direct bolt on replacement IIRC you might have to redrill the holes on the alloy plate that bolts to gearbox, but no mods to the shell or crossmember.
Old Nov 13, 2007 | 07:16 PM
xr4man's Avatar
xr4man
i see.
we have a few individuals and companies that have made a new crossmember specifically for putting the t-5 under our cars. so we just get one of those and bolt it to the transmission and then bolt it to the mounts under the car. no redrilling necessary.
in this picture you can see the crossmember sticking out to the left in front of the exhaust.
and this one you can see it peeking out behind the swaybar.
cheers, ian
Old Nov 15, 2007 | 08:12 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
So what mount is it Dan ????????
Steve.
Old Nov 16, 2007 | 12:35 PM
xr4man's Avatar
xr4man
i'm curious too.
Old Nov 17, 2007 | 07:20 PM
XRSTI's Avatar
XRSTI
so which mount is the replacement then?
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
