lamdba sensor
Old Nov 8, 2007 | 07:23 PM
cossie0_4's Avatar
cossie0_4
Default lamdba sensor
i have a a/f gauge already fitted in my saph but i have a lamda sensor and i am unsure which wire is the signal it has 4 wires 2 white 1 black 1 grey i think the two white are for heater but what about the other two is the black earth and grey signal any help much appreciated cheers
Old Nov 9, 2007 | 07:15 AM
Yura's Avatar
Yura
Default Re: lamdba sensor
What a/f gauge do you have? If it is innovate you may to try use it lamda sensor for a/f gauge and as factory lambda simultaneously ...
Old Nov 9, 2007 | 06:15 PM
cossie0_4's Avatar
cossie0_4
i looks a like a lumenition 1 i have welded a boss in exhaust and have a lamdba sensor spare but dont know what the grey or black wires do i need to find which 1 of these goes to mthe gauge for the signal if that helps cheers
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
