Procedure for bleeding cossie brakes?
Old Nov 7, 2007 | 10:06 AM
rog's Avatar
rog
Default Procedure for bleeding cossie brakes?
I have had the car off the road and basically in a million bits, one of the last things i have to do is put fluid back in and bleed the brakes, what is the best procedure????
Old Nov 7, 2007 | 04:58 PM
rog's Avatar
rog
someone nust have done it before?
Old Nov 7, 2007 | 05:15 PM
Retro Al's Avatar
Retro Al
RWD IS KING
I bought a power bleeder to do my brakes from halfords,no fucking around getting somebody to pump the pedal,just hook it up on to the fluid res, and unlock which ever caliper nipple you want, then plug it into a tyre and it pushes the fluid with no airbubbles, then on to the next one and so on,then i go round again just to make sure,job done all by myself lol
oh and i started with the caliper furthest away first
Old Nov 7, 2007 | 06:54 PM
Azrael's Avatar
Azrael
Cossies have special procedure. You need to be bleeding rears with ignition on.
Old Nov 7, 2007 | 09:50 PM
mechanic28's Avatar
mechanic28
ok chap here we go .......................
to do the rears really it best to have 3 people as it pumps the fluid bloody quick lol
put brake fluid in turn ignition on wait for the abs pump to finish priming itself then start on the n/s/r caliper(furthest away from the master cylinder!)get a milk bottle or something similar get a rubber pipe undo the nipple connect pipe with a ring spanner still on the nipple get someone to press the brake pedal and hold it down fluid will be pushed out f in quick!another person to keep the fluid topped up!when no air is seen going into the milk bottle do up nipple repeat on the o/s/r(dont hold the brake pedal down the more then 10 secs pump will over heat if air is still coming out after ten secs close nipple release pressure from brake pedal allow pump to stop priming itself and give it a minute to cool down then repeat till air out!)
fronts u dont need ignition on just bleed the normal way chap
Old May 4, 2010 | 04:04 PM
BRAMMER's Avatar
BRAMMER
Just followed this procedure and and the pedal is firm and pulls up fine but their is a squeak coming from the left hand side ABS thingy??? is this fine i can't remember if it did it before - theirs no air in the system as the fluid was pissing out
Old May 4, 2010 | 04:58 PM
All I do is cut the abs pump power by pulling the connector from the motor, pos 1 on ignition to open abs valve block, then use me eezi bleed, I am lazy so do the nearest as it's not so far to walk ha ha, works for me no problem, perfect pedal everytime.
Old May 4, 2010 | 06:05 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
just put a power bleeder on the reservoir then go n.s.r o.s.r n.s.f o.s.f untill there is no air bubbles left in the system takes about 20mins if that u will need about 4L if your doing the system from empty and i do it with the ignition on so the abs pump accumulator is pressureized never let me down!. But if u dont have a power bleeder then a mate on the pedal is just as good
Old May 4, 2010 | 06:55 PM
BRAMMER's Avatar
BRAMMER
Test drove and they seem fine, would benefit from a new set of pads but apart from that they're fine
IainRS1700T
Sep 25, 2015 06:44 AM
wattie
Sep 16, 2015 11:34 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
